Noise in an optical ethernet cable measured
newzooreview
« on: 29 Jul 2025, 02:47 pm »
The use of optical Ethernet cables is often suggested as a way to render a streamer or DAC immune to noise from an Ethernet switch, but that is not the case.
Alpha Audio has just posted a demonstration of noise in the switch being transferred into an optical Ethernet cable and back out when converted back to a regular copper Ethernet cable:
https://www.youtube.com/shorts/4_Z6g1hvLks
Noise in = noise out.
Rusty Jefferson
Re: Noise in an optical ethernet cable measured
« Reply #1 on: 29 Jul 2025, 05:51 pm »
All due respect Charles, but this seems like click bait. No baseline of the noise on the switch over ethernet cable vs the optical. Using cheap converter with switching power supply on the ethernet cable output. And introducing almost a half a volt of noise and finding an issue at one megaherz? That noise could be on the electrical ground on that bench. That's not a scientific experiment and they almost say as much on their blog.
..."But what if we start adding noise? We inject 400 mv of white noise (up to 60 MHz) through the Rigol function generator. That’s a lot and quite strong. So take this with a grain of salt."...
https://www.alpha-audio.net/background/a-few-brief-trials-of-fiber-optic-converters/
Edit: spelling
« Last Edit: 30 Jul 2025, 02:55 pm by Rusty Jefferson »
