Hello form Ontario Canada.
0 Members and 1 Guest are viewing this topic. Read 1707 times.
mike52869
« on: 25 Jul 2025, 10:13 pm »
Hello and I would like to thank the moderators for accepting me to this Great forum.
Re: Hello form Ontario Canada.
« Reply #1 on: 25 Jul 2025, 10:38 pm »
Thankyou Mike, you most kind.
Glad to see you reach the stage. :thumb:
Please note some Circles of interest you may like>
The Fullrange Driver Circle:
https://www.audiocircle.com/index.php?board=128.0
The Open Baffle Circle:
https://www.audiocircle.com/index.php?board=90.0
The Tube Amps Circle>
https://www.audiocircle.com/index.php?board=144.0
The Vinyl Circle::
https://www.audiocircle.com/index.php?board=32.0
If you have a hi sensitivity speaker as 100dB and bening impedance curve there is no much things to upgrade IMO, maybe inside the enclosure if you are picky as myself. Today audiophiles can take advantage of inexpensive and transparent powerful Class D or GaN-FET amps and recently with Lii Song Audio, also take vantage of inexpensive big cones full range drivers, this will save a lot of money hence no crossover and no enclosure need.
This is a inexpensive DIY project from an AC member,
It have only four (4) parts:
Eminence Alpha15A + 4.7mH + Visaton B200 and a MDF baffle.
Other option are the Lii Audio F15 FR driver $399/pair, not each.
Here Decware OB with the Lii Audio F15 driver:
If one have a woodworker is possible try the Lii Audio F15($399/Pair, pair not each) 97dB/8Ω and benign impedance curve suited to OB or Bass Reflex box or the F18($540/pair), no Crossover, no Tweeter beaming, no Phase rotation, no driver sensitivity loss, no Harmonics loss, no Retail price.
http://www.glowinthedarkaudio.com/lii-audio-f18.html
My personal choice is the Lii F18 in Single Driver configuration, but if you make question of own a 2-Way speaker you may want a bigger woofer than the Alpha15A, so there are W18 inches and W21 inches from Lii Song Audio, personally I dont like these two VCs woofers, they are hard to drive with a small tube amp, they have two Voice Coils.
https://www.lii-audio.com/product/w-18/
https://www.lii-audio.com/product/w21/
toocool4
« Reply #2 on: 25 Jul 2025, 10:39 pm »
Welcome to AudioCircle mike52869
« Reply #3 on: 26 Jul 2025, 12:00 am »
Greetings & Welcome to AC Mike   :thumb:
« Reply #4 on: 26 Jul 2025, 02:12 pm »
Hi Mike, I'm from Michigan, not far away.  Have been into stereo/audio for over 50 years and have looked into/owned a variety of gear.  I'm into small ensemble jazz and classical mostly but can't tear away from 60's/70's rock.  My hearing is failing and moved into a smaller place where the room is too small for even monitors in a mid-field setup, so switched back to headphones (similar to my dorm room days).
Over the years have gone from single driver designs to 3-ways, to 2-ways but settled on active 2-way monitors for improved dynamics, superior accuracy, and surprisingly deep bass.  Plus the concept of using a sophisticated low voltage crossover and mono blocks directly wired to each driver is undeniable.  Prices run from $300/pair (JBL 305 Mk2) to $15,000/pair (Dutch & Dutch 8C) for really good sound.  Features include no speaker cable, to wireless, to built-in room EQ.
The room is the most overlooked component of the playback chain IMO.  In my last house I had a near perfect room: 8ft x 13ft x 21ft (the Greek Golden rectangle) to reduct echo; insulated walls/ceiling; basement location with no windows; insulated exterior fiberglass door with weather seal; flexible/lined/insulated ductwork (could barely hear the furnace fan); and 3 dedicated 20 amp duplex wall receptacles each on their own circuit and tied to a separate ground.  The effect was spooky to start with but got used to it.  It allowed me to listen quieter and appreciate the dynamics.  Cost for all that, while we were building the house was minimal.  Added room treatments but in that room the effect was minimal.
And remember, have fun.
Bodhi
« Reply #5 on: 26 Jul 2025, 03:09 pm »
Welcome to the forum Mike :wave:.
I.Greyhound Fan
« Reply #6 on: 26 Jul 2025, 06:58 pm »
Welcome Mike from Canada.  That will be a 30% Tariff for joining.  :D
Phil A
« Reply #7 on: 26 Jul 2025, 09:05 pm »
Welcome!
mike52869
« Reply #8 on: 5 Aug 2025, 12:29 pm »
Thank you all for your warm welcome posts. To JLM I too am from Michigan Sault Ste. Marie and now live in Sault Ontario, I married a Canadian girl. But still American!
