Budget Douk Audio A5 Class D Amp Mod- Nice amp addition for audio enthusiast
newzooreview
You could just give Acopian a call. They make everything at their facility in Pennsylvania (or Florida, near NASA) and are likely to have the missing part.
https://www.acopian.com/
« Last Edit: 11 Dec 2025, 05:01 pm by newzooreview »
bbaker6212
Tried the SX52 op amps and found that OPA1656 sounded more clear in the mid-range with comparable bass response, at half the cost.
In my experience, the discrete op amps cost too much and don't contribute a proportional improvement in sound quality.
The Douk A5 is a remarkable small amplifier that performs well above its price class and is replacing a high bias class AB amp in my own system.
For under $130 total with upgraded op-amps & 36v power supply, it is hard to beat.
what front-end/DAC and speakers were you using?
NXSTUDIO-DRUMMER
Nlitworld,
What's the latest updates on your A5 Mod's?  How's it sounding, versus stock with all the significant upgrades you've added to this point? The AC community would enjoy hearing your feedback.
« Last Edit: 22 Jan 2026, 05:41 am by NXSTUDIO-DRUMMER »
nlitworld
Oh I'm sorry I missed this post last weekend or I would have responded earlier. I guess I was too sidetracked with how freakin amazing my stereo has been sounding.  8) Everything has really settled in nicely after the 50hr mark, and now it's really opened up to be just gorgeous. Open, airy, dynamic slam, great tone to guitar and drum (especially floor toms!!) but there's no more edginess or artificial loudness effect anymore. Everything is smooth, well layered in its place, and 3d depth for days. Albums like Jazz At The Pawnshop or Alice In Chains MTV Unplugged absolutely put you inside that room with the performance.
I did also find that leaving this amp on 24/7 helps things as well. For some reason, after the 48hr mark it really sounds good. That could be the circuit itself, or the giant psu caps, but I just leave it on nowadays. Also I have the volume knob about 80% as this unit always had a tiny buzz at full volume on my system. My room is super small and sitting 5' away from speakers means alost any noise is audible. 80% on amp makes my preamp around the 12 o'clock mark, maybe a little more on the real fun listening days but still dead silent with ear on speaker.
As hindsight is 20/20, it really feels all the upgrades are a sum of the parts and that one by itself fixed one issue but creates another. Power supply creates more oomph and drive, but doesn't fix detail. Connectors fixed detail but became too much of a good thing, opamps opened soundstage but doubled down on too much detail, then capacitor mod was final piece to set everything in place. Running the Miflex as my high-pass @90hz was just icing on the cake for opening everything up to a gorgeous sound. I guess it's proof that everything matters and need to create balance. All in all, upgrades are worth every penny of the roughly $600 total invested, and I'd bet you'd all be astonished how good this thing sounds. Most people won't dive head first down this upgrading rabbit hole, but it was a hell of a fun project to learn with the end result being pretty rad! :thumb:
goggle1824
I just wonder how it “MEASURES”!!!  :lol:  :lol:  :duh:  8)
nlitworld
goggle1824
“Whuuuut…?”  :jester:
Clearly how it measures dictates how it sounds.  It’s not .000000001 THD like a digital amp, so this amp is definitely trash.  I don’t even need to hear it to know that!!  SCIENCE!
bbaker6212
super helpful opinion, thanks @cml811.  What about the treble and soundstage/imaging of the 1656 vs SX52?
I'm ready to upgrade the opamps in my A5 now and looking for what is an obvious upgrade from the NE5532 but doesn't add any "warmth", smoothness, etc. as I'd rather tackle that separately with a tube preamp.
My humble low cost system:
PC USB >> SMSL D1 DAC >> FX-Audio Tube-02 Pro >> Douk Audio A5 >> 96db/1w large Open-Baffle 2-way 15" + horn loaded titanium compression tweeter.
I was pleasantly surprised that the FX Tube-02 Pro did help provide some tube-ish warmth/smoothness and maybe a little wider soundstage /presentation.
I haven't tried tube rolling the original tubes yet. 8)
I also want to upgrade the stock 32V 5A power supply.  Prob will go initially with a 36V (6A to 10A)...
I might try a cheap china SMPS to keep cost low - maybe mod it if needed.
bbaker6212
LOL, for a few seconds I thought you were being serious here.
This little thing sounds pretty great with my 96db sensitive big OB's.
bbaker6212
Nlitworld,
he did post a bit more recently about it at this link.
Notice I posted here about the possibility to simplify this mod changing the value of the coupling caps
from 10uF to 0.68uF to create a high-pass filter around 115Hz and so no need for the expensive big Miflex caps used at the amp inputs.
And these 0.68uF caps can be small enough to fit in the stock case for anyone like me who would prefer to do everything in the factory case/chassis.
https://www.diyaudio.com/community/threads/douk-audio-a5.423344/post-8192397
« Last Edit: 3 Jan 2026, 11:16 am by bbaker6212 »
jedics
Hi all, baffled by a problem.
Got a working system, unplugged speakers and input from it to the A5 all working, then the left channel cuts out, I turn it off and on working, then left channel cuts out again, did this a bunch of times and then left channel just stopped working all together. Tried the working right speaker in the left channel and that works fine so it doesnt like my left speaker or cable for some reason. I am just putting the raw wire into the holes of the post and screwing down. Could it have anything to do with me not using banana connectors?
My brain cant compute what is wrong, any suggestions?
nlitworld
So when you swapped the left and right channel speaker wires, the right speaker from the left amp channel was working fine? What about the left speaker plugged into the right channel? Did that start to cut out?
There should be no problem with bare wire in the binding posts, provided they do not touch each other and cause a short. That would trip an amp into protection mode, or worse go poof in a bad way. Banana plugs do make that part easier, but ultimately it shouldn't be an issue.
You were right to start at speakers and work backwards. Check that all the wiring is clean and tidy and isn't touching, and see if that solves it. If it doesn't, then move backwards to the rca cables and swap them. Did the problem move? Keep us posted.
NXSTUDIO-DRUMMER
Note:
If someone should buy a A5, just be aware there are different versions of this model that have been produced. Later versions have the latest upgrades produced by Douk Audio.
Here are some photo examples, indentifying the different versions.
I just zoomed in on my Ver: V3, I did show the location where it will be located on the others, highlighted in yellow. Notice on the Ver:V1 the production stamped date is in a different location. I highlighted it in red. Douk supposed to be releasing a V4 version late april 26'. The new version will have auto-standby mode, that activates after 5 minutes of no signal input.
I'm still enjoying my Staccato op amps, they're TopNotch! :thumb:
Here is another Polish manufacturer of audiophile Op-amps. I've heard some positive comments regarding these Op-amps. Anyone on AC used them?
https://muzgaudio.com/en/produkt/efficient-jfet-operational-amplifier/
This YT reviewer, shows it actually installed in a Douk A5 amp, in link below. If you look closely at his A5, you'll see he has a Ver: V1 amp.
https://www.google.com/search?q=Review+-+Muzg+audio+Jfet+opamp&rlz=1C1UEAD_enUS1146US1146&oq=Review+-+Muzg+audio+Jfet+opamp&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIJCAEQIRgKGKABMgkIAhAhGAoYoAEyCQgDECEYChigATIJCAQQIRgKGKABMgcIBRAhGKsCMgcIBhAhGKsCMgcIBxAhGI8CMgcICBAhGI8C0gEKMjU4NDdqMGoxNagCCLACAfEFN8lHjMMGfrs&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:5afd7fd4,vid:LvNzwuyro28,st:442
Audiophile's never have enough Op-Amp options, for either amps, dac's and preamplifiers.
« Last Edit: 7 Mar 2026, 03:00 am by NXSTUDIO-DRUMMER »
nlitworld
Yep, my first one was a V3 (bought with 48v supply). When I toasted that board, I purchased another with 32v supply which was the V2. Only found out after I tore it apart making a bunch of mods that it was the older version. I can honestly say a V3 is a big step up in sound comparative to each other.
NXSTUDIO-DRUMMER
I have a greater appreciation of class D amplifiers from this experience of owning one now! :popcorn:
« Last Edit: 16 Feb 2026, 08:48 pm by NXSTUDIO-DRUMMER »
NXSTUDIO-DRUMMER
Douk/Staccato Chassis Mod
« Last Edit: 7 Mar 2026, 12:51 am by NXSTUDIO-DRUMMER »
goggle1824
This probably isn’t going to be too helpful but honestly I like both designs! I have been looking and leaving and coming back and looking again, I’d be pretty content with either 😂🤦‍♂️, sorry.  Great job designing them, they both look super cool.
nlitworld
Shawn, that case mod looks like it'll be great. I do like the little blue accents on there too. If you don't already have some House Of Kolor paint or something close sitting around, go pick up some Chrysler Hydro Blue (paint code PBJ). That's the real good looking blue on the new Dodge trucks & Jeeps. Looking forward to how this comes out.  :popcorn:
NXSTUDIO-DRUMMER
Getting close to completion of chassis modifications. Finished milling out the bottom of top chassis, to accomodate the Staccato op-amps. Attached the two chassis, using 4-8/32 x 1/4" Allen head screws. I had some .040 thick Sorbothane left over from my Mordaunt Short upgrade, so I cut a few pieces, and sandwhiched between the two chassis's. Help with resonance? ... can't hurt, plus I already had in hand.
The Air space between the op-amps and the top chassis is 1/2" clearance, therefore, they have plenty of ventalation. I frequently take the lid off anyways, if I'm going to play music louder, pushing the amp further.
With the new turned aluminum Isolation feet, I have more clearance, improving the cool air transfer through the bottom chassis vent holes. I'm also adding 3/4" solid oak side panels to the chassis. Appearance wise, when I viewed the amp, it's tall, but not very wide, so I made the decision to widen it, making it look more proportional to the big boy amps, by simply adding oak side panels. I'm not worried about covering the existing holes on chassis sides, since I remove the top lid for ventalation, the majority of the time. Another benefit with the A5 being powered by a LPS, the amp run's much cooler.
Still working on the front & rear cover plates currently. I'll provide more photo's of the chassis mod when completed.
For now, I've attached a photo of the side panels and new isolation feet. I've stained it in a walnut finish using General Finishes oil based Arm-R-Seal satin finish.
Looking forward to attaching my designed cover plates soon.  :thumb:
Using this amp, going back and forth, between my NX-Studio's and my newly upgraded Mordaunt Short Carnival 2's,
has thoroughly given a lot of listening enjoyment for the family.
Once the front & rear cover plates are complete, that will be the final touch for the chassis modification.
Obviously, work is still in progress, the cover plates are missing. Photo's above, display what's been completed to this point.
After finishinig the panels, I'm going to secure the panels to the amplifier.
« Last Edit: 23 Apr 2026, 02:23 am by NXSTUDIO-DRUMMER »
