Center speaker options for x5 , x4 or x3?
Downtheline
« on: 4 Jul 2025, 03:13 pm »
I am having a tough time integrating a center speaker with my x5 speakers in my media room. Tried a gallo strada, now a kef reference 2. A few other budget options in between. Anybody have any luck? Unfortunately I don't can't do a single x5 in the middle.
Bingenito
Re: Center speaker options for x5 , x4 or x3?
« Reply #1 on: 5 Jul 2025, 08:42 pm »
I would recommend telling your processor that you have no center channel and it will reroute the channel to your left and right speakers… the X5s. Most center channels suck really bad. If you must have one for some emotional reason try to find a pair of X5s cheap and use one.
JCarney
« Reply #2 on: 5 Jul 2025, 08:56 pm »
I'd look at the GR Research X-Voce, or one of the Magnepan center channel speakers. Both are open baffle like your Spatials.
Good luck,
JCarney
Early B.
« Reply #3 on: 5 Jul 2025, 11:46 pm »
Imagine a single Q3 as a center channel. 8)
Downtheline
« Reply #4 on: 6 Jul 2025, 08:44 am »
Thanks all! Ill look into the magnepan amd gr research speakers. I tried a phantom center tonight, and it is a good solution until I can figure out the cemter that works in my room. No space for an open baffle unit unfortunately.
