Baffle reflections,-good or bad?
emtor
« on: 21 Jun 2025, 06:47 am »
Most O/B speakers I've seen have no damping material on the baffle front.
Is this a good or bad thing?
Re: Baffle reflections,-good or bad?
« Reply #1 on: 21 Jun 2025, 06:55 am »
It vary according the room and personal taste.
In this case I think the difference will be minimal IMO.
AllanS
« Reply #2 on: 21 Jun 2025, 12:59 pm »
Are you referring to damping material as you might find in a box speaker?
emtor
« Reply #3 on: 21 Jun 2025, 01:11 pm »
I'm referring to sound absorbing material like felt or foam sheets etc.
MJK
    • Quarter Wavelength Loudspeaker Design
« Reply #4 on: 22 Jun 2025, 10:33 am »
You do not need any special treatments on the baffle face itself. The sound traveling along the front of the baffle will be cancelled by the sound traveling along the back of the baffle (they are 180 deg out of phase) creating a null in the plane of the baffle. This is how the dipole figure 8 sound radiation pattern is created. At low frequencies (<100 Hz) any material you place on the baffle will not be effective.
Sound is not reflected off the baffle.
