Rounded Double Trouble Sub, setup and feedback
0 Members and 1 Guest are viewing this topic. Read 3217 times.
tremrej65
« on: 17 Jun 2025, 02:14 am »
Here's my setup and feedback of my rounded version of the DT sub.
Link to the build: https://www.audiocircle.com/index.php?topic=191642.0
Setup and feedback
First, the feedback.
I’ve been listening to it for over a month now, and I like it. Really like it.
When I was listening to my X-LS Encore as is, without sub, I was questioning myself on why I was building a sub: I really liked the overall balance of the X-LS Encore: the bass is present, very fast, textured and precise. I was a bit afraid of losing that by adding a sub. Where the X-LS Encore was struggling was the extreme bass. That level of bass is present only on a very few pieces of music I listen to. Was it worth the risk? Oh yes it did. The sub enhances the whole presentation of the music, any music.
I added a high pass filter tuned at 70 Hz (68.9 to be precised) on the amp to the X-LS Encore. The sub gives me extreme bass, and the filter gives me more sound level pressure ( I can drive X-LS Encore louder now that it doesn’t handle the extreme bass). And I didn’t lose any precision of the bass. The bass is actually better, more precise, super textured like I never heard before.
The setup:
I use GR Research speaker cable (24 strands)
The filter:
The response:
The setup, how I did it.
Here, nothing new to most of you I guess. For me, I learn a lot.
I use REW software on a Windows laptop with a USB measurement microphone from Hifiberry.
I first measured the X-LS Encore with the high-pass filter. Then I measured the sub.
To tuned the phase of the sub, I used a 70 Hz mono tone signal that I sent to the sub and main speaker simultaneously. I use a SPL meter with REW. I tuned the phase to get the most SPL. The best setup was only two click from zero, i.e. very small adjustment.
Then I played with the different setting of the sub amp to get as close of a flat response I could get.
The rest will have to be tuned with room acoustic treatment. I’ll update you once I get there (not before few months).
The setting of the amp:
That's it for now.
Back to listening to some music...
Rejean
« Last Edit: 17 Jun 2025, 03:30 am by tremrej65 »
Glady86
Re: Rounded Double Trouble Sub, setup and feedback
« Reply #1 on: 17 Jun 2025, 03:54 am »
I had a huge dip centered at around 70hz, Close to the frequency of the rolloff.  Even though I think the output was a tad higher at zero phase,  moving it to 180 degrees out of phase fixed the hole without affecting the other bands much. Using REW, I couldn’t see a difference in measurement with small movements of phase. It sounds good to me, but will try more measurements and tweaking to see if any better performance is possible.
mlundy57
« Reply #2 on: 17 Jun 2025, 07:30 pm »
Interesting look
I like that filter case.  :thumb:
corndog71
  • Some people call me Rob.
« Reply #3 on: 18 Jun 2025, 11:59 pm »
Very nicely done!  Did you make that HPF box?
tremrej65
« Reply #4 on: 19 Jun 2025, 02:35 am »
Yes. I did the design and I printed it. I in-printed the characteristic of the filter on the cover such that if I build a new one I'll know which one is which.
