My Headphones Never sounded better
Mag
« on: 14 Jun 2025, 07:32 pm »
  I installed this Graphic Equalizer Software many years ago but never used it until last night. I've been using VoiceMeeter instead, if I recall correct this was part of the download. Let me tell you my Custom Studios never sounded better. :drool:
Re: My Headphones Never sounded better
« Reply #1 on: 14 Jun 2025, 09:49 pm »
Not sure why you boost 1.0K to 4K.
Do you like beef-up this range?
1k to 5kHz is the range the human ear is most sensitive.
vonnie123
« Reply #2 on: 15 Jun 2025, 04:29 am »
Purists don’t like tone controls, but if you have a little hearing loss it can be useful.  My integrated amp has them.
Mag
« Reply #3 on: 15 Jun 2025, 11:20 am »
The short answer is it sounds right to my ears. The long answer is, I want guitars to sound like guitars and have some edge to it particularly rock guitar. Also having been to live concerts in a good venue like our Auditorium, I want music to sound lively, sound bouncing off the walls, in this case headphones, to achieve that I have to boost the frequencies. And third having a mixer, I played around with it for 2 weeks before using. I discovered that boosting the mid-frequencies gives music its musicality, in fact its a very fine line to nail down. Music can still sound damn good when you don't nail these frequencies, but when you do, music has a bloom to it. :smoke:
Mag
« Reply #4 on: 15 Jun 2025, 11:26 am »
For me it all started trying to compensate for the Fletcher-Munson Curve. To do that you have to use Tone Controls or an Equalizer. The problem with the equalizers I used were the spec distortion was bad and degrading the performance of my higher quality gear. So had to find away that did not mask the sound of better gear. :smoke:
Jon L
« Reply #5 on: 15 Jun 2025, 05:24 pm »
EQ makes a HUGE difference with headphones, but I prefer to start with already-measured baseline for specific headphones, then add some tweaks to taste.  Oratory1990 EQ curves are a giant help  :thumb:
https://www.reddit.com/r/oratory1990/wiki/index/list_of_presets/#wiki_full_list_of_eq_settings.3A
viggen
« Reply #6 on: 15 Jun 2025, 11:34 pm »
i thought hps are less affected by room so less need for eq.
Mag
« Reply #7 on: 16 Jun 2025, 12:15 am »
  I switched to different software as I was having some kind of conflict with VoiceMeeter. Now I'm using Nahimic and even Youtube sounds incredible.
Freo-1
« Reply #8 on: 16 Jun 2025, 01:59 am »
For me, headphone sound took a HUGE jump when I installed PGGB-RT with Foobar 2000.  Amazing software.
AllanS
« Reply #9 on: 16 Jun 2025, 01:22 pm »
True but another potential use case is compensation for hearing loss. I was fitted with hearing aids about 3 months ago and am still floored every night when taking them out how flat and lifeless everything sounds.  Rather than listening through hearing aids I want to mimic the hearing aid program through EQ.
/mp
« Reply #10 on: 17 Jun 2025, 11:59 am »
As Count Orlofsky is wont to sing, chacun à son goût
Which reminds me, I've a recording featuring Lily Pons singing at the Met c.1950. I haven't played it in ~50 years. It's time I dust off the jacket & transfer from the vinyl. That's for a different circle.
Happy listening,
