Has anyone tried changing left/right configuration of Super Alnico HO XRS?
saxguy
I'm wondering if anyone has tried positioning their Super Alnico HO XRS with the upper driver sitting further out than the lower driver.  I always see the upper driver positioned on the inside edge of the speakers.  I can try it both ways, but if anyone has already determined that one configuration is better than the other it would save me from having to move everything around multiple times.
seikosha
Unfortunately, even if someone found one configuration sounded better, unless your taste was identical to his, your room was the same size with the same furnishings, and the equipment was the same, it really wouldn’t matter.  Listen to both and decide what sounds best.  Sorry!
