Super Alnico High Output XRS Toe in?
saxguy
« on: 10 Jun 2025, 06:36 pm »
My Super Alnico High Output XRS should be here on Thursday.  Any suggestions as far as distance from the rear wall and toe in is concerned?
I have some flexibility, as Louis made the pair with integrated powered 8" subs.  I can also plug the rear ports, if necessary, because I'll have the ability to dial in the subs.
toocool4
Re: Super Alnico High Output XRS Toe in?
« Reply #1 on: 10 Jun 2025, 07:12 pm »
Why don’t you just experiment when you get them and let your ears tell you, no one can tell you anything as they don’t know your room.
nature boy
« Reply #2 on: 10 Jun 2025, 07:19 pm »
At least 2' preferably 3' from rear walls. The is minimal side wall reflection from these speakers, so you can spread them out as you like. I preferred toeing them in just outside my ears in the listening position. Try to seat yourself with your head (ears) at the height of the top driver of possible.
NB
