LampizatOr Genya sees it's first pro review
0 Members and 1 Guest are viewing this topic. Read 10235 times.
Gopher
« on: 6 Jun 2025, 03:16 pm »
I'm pleased to report the first review of our brand new Genya DAC dropped today:
https://hifiknights.com/reviews/sources/lampizator-genya/
To say this unit is a supreme value would be an understatement!
musicdre
  • reality is the base
    • art site
Re: LampizatOr Genya sees it's first pro review
« Reply #1 on: 6 Jun 2025, 04:50 pm »
thanks for the post.  whats the price?  its not readily apparent in the review
JCarney
« Reply #2 on: 6 Jun 2025, 05:17 pm »
Straight from the review:
"Lastly, beefy output signal caps used in Genya are niche copper-foil polypropylene types. The Genya „Lite” version as reviewed sells for €16’000 and later on this year we’ll also see its two other siblings. The fancier Genya Plus priced at €19’000 will feature cherry-picked ECC182 tubes and gold-plated PCB, while the €12’000 Genya R2R will rock a digital stage with vintage AD1862 D/A converter in it."
JCarney
