Dumb question #21
0 Members and 1 Guest are viewing this topic. Read 10673 times.
GeneS
Dumb question #21
« on: 4 Jun 2025, 11:24 am »
I have a pair of preamp outs on my Candela preamp.
What are they for?
Delta77
Re: Dumb question #21
« Reply #2 on: 4 Jun 2025, 10:29 pm »
That is where you plug your amps into.
Connect the PREAMP (rca) outputs to the AMP's (rca) inputs.
Usually one set will run the Front Speaker's amp, and the other set will run the subwoofer's amp/amps.
By use RCA cables, the sources (TT, Streamer/DAC, CD player) are plugged into the Preamp for Volume control and switching sources, then the preamp is plugged into the amp.
klaus@odyssey
« Reply #3 on: 4 Jun 2025, 11:28 pm »
Hey Gene,
Guessing that you're asking about the horizontal connectors...2nd outs for either biamping or subs
GeneS
« Reply #4 on: 5 Jun 2025, 12:54 am »
Thank you, my friend :thumb:
And thank you to my other friends who replied who I haven’t met yet! :thumb:
justjed
« Reply #5 on: 8 Jun 2025, 03:13 am »
I use the second pair of outputs for a headphone amp, mostly. Sometimes I biamp my system. There are many uses for extra outputs.
opnly bafld
« Reply #6 on: 8 Jun 2025, 12:22 pm »
Or a pair Y cables can be used if your pre has 1 output.  :wink:
