0 Members and 1 Guest are viewing this topic. Read 8814 times.
The comparison seems to be between two comparably poor methods of connecting the DAC: USB directly from a PC or via Toslink to a WiiM Ultra.If you enjoy the system then it doesn't much matter, but this "simple/inexpensive trick" is not going to get the best sound from most systems.
You can avoid the need for optical isolators if your streamer or DAC have galvanic isolation.
.... but I cannot hear the difference between plugging the USB cable from my computer directly into my DAC, or doing what I suggest above....
....What I am trying to implement is galvanic isolation with equipment you may already have, or with equipment which is budget level.
Do you hear a difference between using the internal dac in the Wiim and the external SMSL? You could pass a A/B/X test?That is an over simplification (imo). It's not that simple. Because you're confident it will have an audible improvement on this system?
