Anyone using RGGB-RT with Foobar 2000?
0 Members and 1 Guest are viewing this topic. Read 2618 times.
Freo-1
« on: 13 May 2025, 08:44 pm »
I recently stumbled across the RGGB-RT plug in for Foobar 2000.  I tried this with CD files, and the difference is quite noticeable.  Upscaling 16 Bit/44.1 KHz files to 32 bit/176.4 sounds better with the loudspeaker setup (Devialet 1000 Pro, ATC SCM 40, SVS PC4000).
Where the differences are really noticeable is with the headphone setup, where I can take advantage of 32 bit/705.6 KHz.  This is a very nice upgrade, and best of all, its a no cost upgrade on the software side.  One does need a Windows computer with some oomph (8 Core-16GB) to take full advantage of the software.
So, anyone using this?
« Last Edit: 20 May 2025, 12:25 am by Freo-1 »
Freo-1
Re: Anyone using RGGB-RT with Foobar 2000?
« Reply #1 on: 19 May 2025, 08:24 pm »
Been using this for about a week now, and it continues to be impressive.  I think many audiophiles would find this a more significant upgrade to their system than changing out components.
Highly recommended for audition.
https://www.foobar2000.org/components/view/foo_pggb_rt
