AMG STA stability into 2 ohm load
0 Members and 1 Guest are viewing this topic. Read 7680 times.
sidvee
« on: 5 May 2025, 06:21 am »
I am planning to drive Wilson Sabrina's with an AMG STA.  I believe these speakers dip to 3.2 ohms, will that be an issue for the AMG STA?
Sid
muellec3
Re: AMG STA stability into 2 ohm load
« Reply #1 on: 5 May 2025, 01:33 pm »
Hi Sid
I use the STA to drive my Gauder DARC 60 which go down below 3 ohm as well. The amp has no problem with this and sounds great with them - I have not heard it paired with Sabrinas though…. Chris
« Last Edit: 5 May 2025, 10:43 pm by muellec3 »
sidvee
« Reply #2 on: 6 May 2025, 04:39 am »
 Thank you @ muellec3.
Sid
AllanS
« Reply #3 on: 6 May 2025, 10:21 am »
Jason will hopefully weigh in but I can add that I never had a problem driving my M4 Sapphires that, near as I can tell, have a 3 ohm excursion somewhere south of 100 hz. That said, I’m guessing the answer depends on how loud you listen and where the dip occurs.
rustydoglim
« Reply #4 on: 7 May 2025, 02:45 pm »
The issue is over-current protection.  If the load is 2 ohm and some speakers require high current, then the amp could temporarily shut down due to over-current protection.
In most cases it will be ok.  3 ohm is ok.
sidvee
« Reply #5 on: 14 May 2025, 05:55 am »
Thanks Jason.
Much Appreciated.
Sid
