4B3 maintenance
alanford69
4B3 maintenance
« on: 1 May 2025, 12:59 pm »
Hello do Bryston power amps need any kind of service after a given number of years? I have a 4B3 purchased in 2015 and I have no issues but I was wondering if it was worth a check to be safe for another 10 years ;-)
alanford69
Re: 4B3 maintenance
« Reply #1 on: 3 May 2025, 12:56 pm »
Hello anybody owns a 4B3 since 10 years? I Just would like to know if there is any service schedule to keep it fully functional and providing the best performance. Maybe anybody from Bryston could advise?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 4B3 maintenance
« Reply #2 on: 3 May 2025, 01:28 pm »
Hi Alan
We have Bryston amps from over 20 years ago that are still performing well within spec - so I would not be concerned unless something is amiss.
james
alanford69
Re: 4B3 maintenance
« Reply #3 on: 3 May 2025, 01:36 pm »
Thanks James! I just wanted to be sure… I love my 4B3 and wanna keep it for long!
Re: 4B3 maintenance
« Reply #4 on: 4 May 2025, 12:10 am »
I will tell you a story from the past:
Jack Renner from Telarc Records would record Oscar Peterson and Ray Brown in a recoding studio in Toronto called Eastern Sound.  Whenever he would come to town he would ask me to bring down some amplifiers so he could record using Bryston amps.
One time when I was sitting in on a session the owner of Easter Sound came into the room and asked me to come with him to another studio down the hall.
Behind some glass were 6 Bryston 4B amplifiers and he asked me - "how long do you think they have been on" I said 'no idea'.
He said with a smile - 23 YEARS. :)
james
« Last Edit: 26 May 2025, 11:54 am by James Tanner »
gbaby
Re: 4B3 maintenance
« Reply #5 on: 4 May 2025, 12:59 am »
Continuously? :o
Re: 4B3 maintenance
« Reply #6 on: 4 May 2025, 01:55 pm »
Yes I told him whatever you do "DONT TURN THEM OFF"  :lol:
gbaby
Re: 4B3 maintenance
« Reply #7 on: 4 May 2025, 02:36 pm »
Damn! :o :o :D
Speedskater
  • Kevin
Re: 4B3 maintenance
« Reply #8 on: 4 May 2025, 03:03 pm »
Not Continuously!
in 2003 (I think) there was a major power outage, that took out eastern US & Canada AC for several days.
gbaby
Re: 4B3 maintenance
« Reply #9 on: 4 May 2025, 04:33 pm »
Not Continuously!
Even with this, its still a magnificent accomplishment.
alanford69
Re: 4B3 maintenance
« Reply #10 on: 4 May 2025, 07:36 pm »
Wow amazing! 🤩
Jozsef
Re: 4B3 maintenance
« Reply #11 on: 26 May 2025, 02:07 am »
If you think back, it was Eastern Sound, old son.  :wink:
My 2.5B Cubed is as old as they come, it's used every day, turned off every time there's a power failure, and it's still perfect! This is not the modern, toss it and buy a new one philosophy that's so common today.
Re: 4B3 maintenance
« Reply #12 on: 26 May 2025, 11:55 am »
Thanks Jozsef - fixed.
budt
Re: 4B3 maintenance
« Reply #13 on: 27 May 2025, 01:48 pm »
  I sent an amp in 12 weeks ago. I was told I would have it back in 8 weeks . I didn't make any call to them until last week( week 11).  I tried calling twice  and left messages but  didn't get a response. I tried again today but it goes straight to voicemail . The last time I sent an amp in ( about 15 years ago) I had it back in a week or two . I also had no problem contacting them. As it is now  I have no idea if I will get it back in a week or 6 months.  I just wish I knew and if it's going to be 2 more months or something I will have to go out and buy a relatively cheap amp to hold me over.
Re: 4B3 maintenance
« Reply #14 on: 27 May 2025, 02:37 pm »
Hi Budt
I will ask.
james
Hi - can you send Jim and email please - [email protected]
Solarflares
  • Musical Guru and part-time Oxygen-Thief.
Re: 4B3 maintenance
« Reply #15 on: 7 Aug 2025, 08:53 am »
After 10 years, it would be a good idea to put the amp on it’s front. Then, using straight, un-lubricated contact-cleaner with the thin applicator tube attached, and a lint-free cloth - squirt short bursts into the edges of the slots of the 5 slider switches.  Then jog the switches 10 or so times.
alanford69
Re: 4B3 maintenance
« Reply #16 on: 31 Dec 2025, 03:33 pm »
Thanks, not sure I understood what i should do (english is not my native language :D) but, first of all @James Tanner do you support this type of operation or may it possibly void the warranty?
Re: 4B3 maintenance
« Reply #17 on: 31 Dec 2025, 04:30 pm »
Hi Alan - yes this is OK
james
alanford69
Re: 4B3 maintenance
« Reply #18 on: 31 Dec 2025, 04:51 pm »
Thanks, I did not understand on which switches I should apply the contact-cleaner, @solarflares could you be more specific? I just want to be sure…
Stefan_DR3
Re: 4B3 maintenance
« Reply #19 on: 1 Feb 2026, 05:58 pm »
There are no slider switches on the 4B3 (like those on the 4B2).  They use toggle switches for GAIN, MODE, INPUT.
It's not a bad idea to clean the contact of any moving switches but I am not sure if this style of toggle switch can be cleaned like that.
