BR-20 single-ended analog out
alanford69
« on: 30 Apr 2025, 06:42 pm »
Hello @James is there any loss of quality if I use the RCA output from my BR-20 to drive an unbalanced power amp? Is there any doc explaining how the unbalanced output circuit works? Thanks!
  • The Demo is Everything!
    • http://www.bryston.com
Re: BR-20 single-ended analog out
« Reply #1 on: 30 Apr 2025, 07:20 pm »
Hi Alan
No DOC as such other than the fact that balanced lines eliminate any outside RF interference from getting into your system.. In short runs RCA is fine.
james
alanford69
« Reply #2 on: 30 Apr 2025, 09:12 pm »
Ok thanks so still class A, no integrated opamp etc. I mean same “clean and pure” signal path, correct?
« Reply #3 on: 30 Apr 2025, 10:44 pm »
Correct.
james
