The dspNexus 2/8 for speaker frequency response correction with Magnepan 1.7i's
0 Members and 1 Guest are viewing this topic. Read 7925 times.
HAL
Have a pair of used stock Magnepan 1.7i's in for testing for dspNexus 2/8 use in my room.  This is with the original passive crossover in use.  Here is what the measurements show and what is possible with the system using REW for the measurements and frequency response corrections.
The 58Hz dip in response is the ceiling to floor cancellation at my seat with the placement of the speakers.  Both speaker channels are frequency corrected independently.
This is what correcting your speakers, in your room, in your listening seat can do.  And yes, they sound much better. 🙂
Stock passive crossover as setup:
Applied REW frequency response correction to the same speakers:
jtwrace
    • TIPP YouTube Channel
The use of a passive crossover is just so wasteful anymore unless one wants a simple set and forget setup.
The best crossover is one in the digital domain!
HAL
I agree.
If people that own a speaker system and do not want to modify them for direct drive they can still see a large improvement.
Later, if they decide to modify the speakers for direct drive they can use the dspNexus 2/8 for that as well with a different DSP crossover design, no new hardware needed for more improvement.
maty
Question:
How do you minimize the PHASE SHIFT produced when equalizing with REW? It's audible from 300-400 Hz. For lower frequencies, there is no problem.
Obviously, I am thinking about high-quality, dynamic recordings (DR > 11 dB), with real instruments and vocals without Autotune.
HAL
With REW I am making no attempt to adjust the phase of the response other than what the IIR filters apply.
I listen to unamplified classical music and vocal music and I do not detect any phase problems affecting them after correction.
If a user wanted to do processing for phase response correction within the capabilities of the ADSP21569 dspBlok, then they can use other software tools to create the filter coefficients for processing and import them to the processing block needed in Audio Weaver.
HAL
Decided to add my two open baffle 1x12 H-Frame subs to the 1.7i's and chose 125Hz as a crossover point.  I did time delay measurements from the 1.7i's and each sub and added the delay to each 1.7i.
The sub are near the 1.7i's with a similar ceiling to floor dip in response.
This is the REW response plot of both speakers at my listening chair with the MM-1 measurement mic setup at ear height, pointing at the ceiling with the 90deg calibration data.
