DSP Nexus and my setup???
rhale64l7
« on: 25 Apr 2025, 12:10 pm »
I have been considering a DSP crossover for my system. But ai am wondering if this would be overkill for my application. I have an Anthem AVM90 that I use that has a very good eq system. So I would mostly be using this for strictly the active crossover and time alignment of drivers. My system is s AVM90 going to a Sublime Acoustics kt235 into 6 Orchard Audio Ultra modules. 3 per speaker. My speakers are SB Acoustics Sasandu Textreme's. They are angled baffle speakers. I could use an OEM version of this I suppose. Anyway how would I get help with developing a good solution for these speakers when you don't have any to test? I see you did a great job on the Maggie's and CSS speakers. But you can and have bought them to test. These can be bought now. But how would I get help? And how much better would it be? If I were using my Anthem AVM90 for the DAC and equipment part. Thanks for any help.
HAL
Re: DSP Nexus and my setup???
« Reply #1 on: 25 Apr 2025, 01:06 pm »
When I sell the dspNexus 2/8 I do the customer DSP crossover design.  The customer makes measurements in his room for use in the new design.  If you can make REW measurements with your existing setup with REW, then those can be used as well.  I can discuss this process if needed.
Once the dspNexus 2/8 system is setup, you can use your phantom powered measurement mic, cable, stand and the dspNexus to make the needed frequency response measurements with REW for the new design.  Something like the Dayton Audio EMM-6 or Beyerdynamic MM-1 are fine for the measurements with REW as they have calibration data available after purchase.  There is a phantom powered mic XLR input on the front panel to make connection and with Measurement mode drives REW.
The dspNexus 2/8 would go between the AVM90 and Orchard Audio amps direct driving the speakers.  It would replace the Sublime Acoustics crossover.
The dspNexus 2/8 becomes the 8 channel DAC output to the Orchard Audio amps.   The AKM AK4499EX DAC's are excellent DAC's.
If multichannel decoding is needed, the AVM90 decoded stereo analog outputs can feed the inputs on the dspNexus 2/8.
Let me know if you need any other information.
rhale64l7
« Reply #2 on: 25 Apr 2025, 01:27 pm »
Yes this will be a dual use setup as you have probably figured out already. I use it for music and movies. Your system is the only DSP based that I could see using. Because of the 4499ex Dacs. I have said I am not going to use inferior Dacs after my processor. It just doesn't make sense.
Are you using the newer DSP engine yet? Or still working on it? Thank you for the quick reply.
How much of a sound change could I expect?. Would it be worth the expense?
HAL
« Reply #3 on: 25 Apr 2025, 04:02 pm »
The production dspNexus 2/8 with the AK4499EX DAC's uses the Analog Devices ADSP21569 DSP processor.   This was an included upgrade to the EA systems that came with the ADSP21469 DSP.
I am not familiar with the AVM90 sound.
In custom installs for each customer to date, the sound quality of the upgraded dspNexus 2/8 has been a sound quality improvement over the existing system.  That is in comparison to live orchestra hall concerts that one of the customers attends regularly over what he had previously.
rhale64l7
« Reply #4 on: 26 Apr 2025, 04:00 am »
How would I leave the eq for my mains out of my ARC Genesis solution? It eq's all channels and balances the sound between 9 speakers for my home theater. So then it would be r- eq'd. If I could figure out a way it might work. I know the AKM 4499 Dacs are very good. I have the Sabre 9038pro in the Anthem. But it doesn't sound like a ESS DAC. I compared the 4499 to it and I liked both for different reasons. I could live with either. Thanks for all your help. I wish I could have talked at Axpona but unfortunately the partner in crime broke her foot. Maybe next year.
HAL
« Reply #5 on: 26 Apr 2025, 11:10 am »
One method would be to use the USB or S/PDIF digital inputs on the dspNexus 2/8 for sources and bypass the ARC Genesis on the Analog inputs.
A PC, MAC or streamer with compatible digital output could be used as input and the dspNexus Control center with remote can switch inputs and do the volume control with the AK4499EX DAC's.   The PC would be there to run Audio Weaver for the program with the XMOS driver for USB input for programming and USB Audio.
Glad to help.
danvillesignal
    • Danville Signal
« Reply #6 on: 1 May 2025, 02:36 pm »
I would like to comment on the AK4499EX based DACs in the dspNexus.
The dspNexus was designed with the expectation that as technology improves, DACs, the ADC and DSP can be upgraded.
During the dspNexus development, I made several modules based on TI DACs, a WM8741/42 DAC, and multiple AKM based DACs.
I made two different AK4499 based DACs, one with the pre foundry fire AK4499 version and later with the AK4499EX version. Both AK4499s are very similar sonically and the best DACs I have used.
I think the much lower priced AKM AK4493SEQ that we use in many of our products is also better than any of the ESS Sabre parts. I realize that this falls into opinion, but I can use whatever I want in the dspNexus.
The choice of the semiconductor DAC is the starting point. Just like fine cooking, the ingredients matter, but there is also more to it. Most playback DACs (the complete product that consumers buy) are typically the manufacturers' reference design implemented with a new PCB and a nice shiny box. I don't do this with the Danville products. I use alternative supporting circuits and also scale the levels to match well with the various sensitivities of amplifiers and loudspeakers.  Rich tells me my AK4499 based DACs perform better than other AK4499 based DACs and certainly better than other non-AKM based DACs. My goal is to provide best of class performance even if you weren't using DSP. This means that even though you are buying 8 channels of DACs instead of just 2 channels, you are not compromising.  If you were only using 2 channels of a dspNexus, it would be as good or better as any DAC you are likely to buy at any price.
Al Clark
Danville Signal
rhale64l7
« Reply #7 on: 1 May 2025, 06:30 pm »
It's funny as I was just coming here to ask another question about this. Say I do my measurements in my room and we get it dialed in nicely. What would happen if I moved into a much better room for the system? Could I then come back and start over in the new room? Or would it be better to take it all outside and test it in free air so that I could just run ARC on top of it to clean up the room?
 I know those DSP's are good. And better than most Sabre implementations. But Anthem really did a great job on this. And I for some reason am not bothered by the Sabre sound.
Actually I am so curious to see how much better my system could sound. From the sound of it,it would be endgame. The Dynaudio Confidence 20A really took Axpona by storm with the DSP and all in the stand. It looks cool too. But mine should sound even better than that. I have spared no expense except my crossover.
So what kind of improvement would it make is the question. It would be nice if it had a trial period. Lol.
 I do appreciate the explanation on the surrounding components. Would a computer have to be used full time with the filters? Or just when programming the Nexus?
HAL
« Reply #8 on: 1 May 2025, 07:26 pm »
If you move the system to a new room, new REW measurements at the listening position would be needed and input to the DSP crossover design,  This can be done with the PC and Audio Weaver at any time,
The system can be used in two different ways.  First is running Audio Weaver live with the dspNexus 2/8 for measurements and listening trials.  The second is if you are satisfied with the system sound, Audio Weaver can Generate the binary file for Flashing the dspBlok.  Then the system runs the DSP crossover every time at power-up.  As an example, the dspNexus 2/8 comes with a simple 3-way L-R crossover with extra sub channel Flashed to the dspBlok so the system is running at power-up.   That can always be replaced at anytime with the new DSP crossover design for your system.  The PC is no longer needed after Flashing the dspBlok.
We have found that ROON based systems for digital need the PC as a ROON Bridge since it has the USB XMOS driver that works correctly for the dspNexus.
For my sales and support of US customer dspNexus systems, I offer a 2 week trial period.  This way an informed decision can be made.  The customer has to pay the s/h both ways in case they decide they do not want to keep it.  It would be drop shipped from Danville Signal and returned to me in that case.  I do not do export systems, for that Danville Signal would be the sales point and they have their own policies.
Hope that helps.
danvillesignal
    • Danville Signal
« Reply #9 on: 1 May 2025, 07:35 pm »
Most of your questions are better answered by Rich.
The short answer is that dspNexus can be programmed for different targets and certainly different rooms. At Axpona, we had a basic crossover design and then optimized it to address low frequency bass management issues that are always room dependent. We are modifying that design in the internal Danville sound room for a different subwoofer integration. This is one of the advantages of DSP; crossovers are configured in software, no soldering required.
Concerning the Sabre DACs. I hope I didn't imply that they are bad. They are good and there are many good implementations of them. My view is that the various AKM devices are better. This should be taken as opinion, not absolute fact.
Al Clark
Danville Signal
rhale64l7
« Reply #10 on: 1 May 2025, 08:12 pm »
Definitely no offense taken about the Sabre Dacs. I am actually perplexed how I can stand them as I don't like a bright character. And most find the AKM smoother. And actually I do too when hearing them side by side. But there is something I like about the Sabre Dacs sound. I could live with either.
 Also how could I talk to Rich? I am not ready to pull the trigger just yet. But I am seriously considering the endgame.
HAL
« Reply #11 on: 1 May 2025, 08:23 pm »
I am Rich.  :D
Send me a PM here.
rhale64l7
« Reply #12 on: 5 May 2025, 03:52 am »
Ok some more questions. How about circuit board design and ground planes and all the good stuff. Resistors? Was everything designed well? I know I read someone had a question about the power supply. But you gave a good answer that explained the reasons. This would be a huge change for me. So I just want to make sure I am not going to degrade anything. Thanks again for answering my questions.
Ron
danvillesignal
    • Danville Signal
« Reply #13 on: 6 May 2025, 01:39 pm »
All Danville products are built using good components and techniques.
If you are going to design and build high performance audio products there is not one or two "magic" things that make all the difference. It is a combinations of many small decisions that have a collective effect.
I have been designing audio products professionally for 50 years both analog and later DSP. Danville Signal is now 27 years old and we have been doing our own manufacturing for more than half of this time.
If you look inside our boxes you will see very few cables. We tend to build "clean" designs.
To your specific questions:
1. We use a lot of ground planes and power planes on our boards. The way you route your design is important for both audio performance and EMC considerations.
2. Most components are surface mount. This minimizes lead inductance and is efficient from a manufacturing perspective.
3. In all of our audio products, we use thin film resistors in the signal paths. We use good quality parts through our designs.
We are not in a race to the bottom. Our products will never be the lowest cost, but they are also not "bling". You won't find half inch thick metal work with the finish of a telescope lens in our products either.
If you or anyone else is interested in a further discussion, I am available via phone or video call. There is a contact form on the Danville website.
Al Clark
Danville Signal
rhale64l7
« Reply #14 on: 6 May 2025, 05:53 pm »
Ok thank you. I appreciate your answers. I have my stuff up for sale. When it sells I. Will be looking this way first.
rhale64l7
« Reply #15 on: 16 May 2025, 04:14 am »
Ok I think I have my stuff sold to buy this DSP Nexus2/8. I am going to want it in black. I think I will get it through Leo at Orchard Audio seeing as I have bought so many modules from him. I am wondering how long is the wait on a black version? And will I get the same support if I buy from him? And will I get the same return policy if I don't like it? Also how long until I get some crossover stuff done and returned to me to test? I will want some exotic stuff if it sounds better. I am willing to keep experimenting. I am always in search of that beautiful smooth timing. With lots of rhythm and pace.
HAL
« Reply #16 on: 16 May 2025, 12:28 pm »
The dspNexus 2/8 is only available in the one color scheme, no black version is planned.
You receive the same support and warranty from Leo and he has the bundled systems.   I do the customer crossover design in both cases.
Once you purchase the dspNexus system, measurement mic, cable and mic stand have the system setup and start making REW measurements of your speakers at your seat.  I recommend a measurement mic like a Beyerdynamics MM-1 calibrated mic where you can email for the calibration curves for 0 and 90 degrees to use with REW.  The mic, cable and mic stand can be purchased via Amazon or music stores.
Once I see the measurement data is it usually less than a week for the DSP crossover design to be ready for testing.  The REW measurement files are emailed to me and once complete I email the crossover block diagram.
The system comes with a license for DSP Concepts Audio Weaver.  Danville will setup your account and send you the link to download the Audio Weaver version needed for the dspNexus 2/8.
rhale64l7
« Reply #17 on: 17 May 2025, 02:55 am »
Ok but I don't have passive cross overs in my speakers. So I would need something to protect my tweeters from full range sound correct? Do you have some safeguards in it to protect that? Do I need to let you know what I have in my active crossover now? I want to experiment but where to start? Sorry for all the questions.
And after watching your videos I have some understanding here. And I also remember you at Axpona in 2024 I stayed for the demo and thought it was good. But I'm not a Maggie fan sorry. I just don't like the wall of sound thing I guess. But your technology was interesting. At that time though I wanted to not downgrade my Dacs. Now you are ahead of my Dacs so we are good.
HAL
« Reply #18 on: 17 May 2025, 11:10 am »
For your speakers, no passive crossover is needed as the dspNexus 2/8 will be the bandwidth limiting system for the drivers for protection.   The limited bandwidth goes to each driver in the speaker as in your Active crossover.
If you have parameters for your existing active crossover, that is a beginning, but speaker measurements will give the full information needed for an improved DSP crossover and also the corrections needed.
I have used the dspNexus 2/8 for DSP crossovers for many other types of speakers for customers.  Planars are just one of the types.
rhale64l7
« Reply #19 on: 17 May 2025, 05:59 pm »
Yeah I know about the different speakers. You even mentioned the one with the Satori drivers. I have pretty much decided this is the way I need to go. I am an endless tweeker, and  I am never satisfied.
