Sony WH-1000XM5 L/R balance
0 Members and 1 Guest are viewing this topic. Read 4132 times.
peterpa
« on: 21 Apr 2025, 07:16 pm »
I love these phones but just noticed the Right one is almost silent, everything is in the Left. As an old (very) stereo guy my definition of balance refers to L-R relative volume. This seems not to be in the Sony app. Any ideas?
Pez
Re: Sony WH-1000XM5 L/R balance
« Reply #1 on: 21 Apr 2025, 07:46 pm »
I own a set of these and they are excellent. My only guess into what the issue is would be a hardware related problem. Aside from the spatial sound optimization and EQ there aren’t a ton of things one can do to mess with the settings within the Sony software.
However there is the potential that your phone may have its own settings for balance. If you are using an iPhone follow these steps: Settings > Accessibility > Audio & Visual under that menus check to make sure “balance” is centered. It should be at the bottom of the menu. If it’s Android you’ll have to look it up. I’m not sure how to fix for that OS.  :thumb:
Mag
« Reply #2 on: 21 Apr 2025, 10:03 pm »
   My guess is your phones are not Pairing correctly. There can be more than one type of driver and its not connecting to the driver intended for these phones.
  When I use Amazon Music app on PC it will list devices that I can connect to. And there can be more than one listing for the headphones I'm using. Usually the default sounds the best, selecting another may sound tinny although it still works.
peterpa
« Reply #3 on: 5 May 2025, 09:20 pm »
Thanks to Pez and Mag. My phone is Android and the problem is with my PC (youtube). There doesn't seem to be much to adjust. I haven't used them for anything else, so that's my next step.
Pez
« Reply #4 on: 5 May 2025, 10:05 pm »
Glad to help.
Oddly enough, I also have the earbud equivalent of these the WF-1000… and guess what? The right ear bud just stopped working for no reason last week. Seems to be hardware related unfortunately.   :scratch:
peterpa
« Reply #5 on: 5 May 2025, 10:18 pm »
Would anyone recommend phones that are as good as Sony WH-1000XMS, but with better controls? One problem I find is they frequently switch to a mode where if I cough they pause the streaming.
Pez
« Reply #6 on: 5 May 2025, 11:13 pm »
You can adjust those setting in the Sony Sound Connect software. Do you have that software in your phone?
peterpa
« Reply #7 on: 6 May 2025, 12:42 pm »
Yes but I don't see a L-R balance adjustment.
