Recommended speaker wire length, can it be too short?
0 Members and 1 Guest are viewing this topic. Read 1917 times.
JBELT01
I did a quick forum search for short speaker cables but did not find anything so I am asking for a little help.
Going to try some monoblocks with my NX-Otica's.  The amps will be within 6" of the speakers.  Speakers have tube connectors at present and Danny's DIY speaker cables that are 15' long.  The Oticas are over 8' from the front wall where the current electronics are placed.
Is there a minimum length for a speaker cable?  Building a set of Danny's cables 6" long seems like a lot of work for potentially very little benefit.  What is the shortest they should be to still get the filtering benefit?
Would it be better to solder on a 6" extension (using Danny's internal speaker wire) to the the back side of the female tube connector and connect the other end to the amp with a banana plug for easy/safe disconnect if the amp should get accidently bumped into?
Other solutions?
I am cautiously optimistic about going to the Topping B200 amps but if they don't work out then I will likely go with Bryan Miller's tube amp that Danny and Ron have both given positive reviews and in which case the existing 15' cables will be just fine.  I do not want to modify the existing set up in a way that cannot be easily undone.
Thanks in advance for your help!
Hobbsmeerkat
Re: Recommended speaker wire length, can it be too short?
« Reply #1 on: 24 Mar 2025, 10:22 pm »
Generally speaking, the "better" option is short speaker cables, long interconnects, so a pair of 2-3 foot speaker cables is perfectly fine, it's just not a super common site.
For the ideal level of filtering on power cables, Danny recommends sticking between 5-6 feet, with 4 feet as the shortest available option, so 4 feet would be the recommended minimum for speaker cables as well, but you can go shorter if needed.
PumaCat
« Reply #2 on: 25 Mar 2025, 04:28 am »
Other solutions?
Per your question, which is an insightful one: "Is there a minimum length for a speaker cable?"
Answer:Yes.
Some info for your consideration: important to remember that the signal is an EM wave that propagates along the cable, the signal is NOT like water flowing through a hose or marbles (i.e., electrons) rolling in a tube,  so to speak.
Additionally speaker cables carry an alternating current (AC) signal, representing this audio EM waveform, it is not DC.
As such, speaker cables are susceptible to the influence of noise caused that can be caused by EM wave reflections of the AC signal if the speaker cables are too short. This noise is usually perceived by the listener as "blur and slur" of the musical presentation.
As such, in my experience and acc. to some cable manufacturers I know in the audio cable industry, speaker cables should be a minimum of 1.5M in length. This is to mitigate the impact of these EM wave reflections carrying the signal from the amplifier to the speaker drivers.
it's also very beneficial to raise the speakers off the floor using speaker cable elevator as vibration imparted by the floor can impart triboelectric noise the speaker cables dielectric insulation. I'll add that even a slab floor can, and does...vibrate. At a specific resonant frequency, concrete quite literally can, and does, ring like a bell.
Here's a link to some affordable speaker cables elevators:
1) https://shorturl.at/LgzxM
2 The Cardas cable elevators designed by well-regarded cable engineer, George Cardas:
https://www.dedicatedaudio.com/products/cardas-multi-block-cable-elevators
Just some physics info for your consideration. Cheers.
Speedskater
  • Kevin
« Reply #3 on: 25 Mar 2025, 12:22 pm »
When a skilled loudspeaker designer voices a speak, he uses a cable. That cable is a small part of the voicing equation. It would be good to use a cable wit a similar total end-to-end resistance.
corndog71
  • Some people call me Rob.
« Reply #4 on: 26 Mar 2025, 03:03 am »
FWIW, active speakers use very little speaker cable between the amp and the drivers.  So, I wouldn’t worry about it.
Under normal circumstances I do recommend getting a little bit longer than you think you’ll need.  You never know when you’ll need to reconfigure and a little slack helps.
