Snap, Crackle & Pop -- Please Make it Stop!
0 Members and 1 Guest are viewing this topic. Read 3045 times.
Early B.
« on: 17 Mar 2025, 07:21 pm »
My buddy has a nice system consisting of a tube amp, tube preamp, DAC, and transport. Recently, he has been experiencing loud popping sounds after a few minutes of powering up. It sounds like intermittent popcorn static. This sound comes through the right speaker. To troubleshoot, we swapped the left & right tubes on the amp and preamp, but the sound remains on the right side. It occurs when no music is playing, as well. The weird thing is that the popping sound doesn't occur until the system is warmed up.
How should we proceed with troubleshooting?
Thanks.
Re: Snap, Crackle & Pop -- Please Make it Stop!
« Reply #1 on: 17 Mar 2025, 08:01 pm »
Thanks.
In the late 1980s I had a similar prob it was a pop that danced according the music in the tweeter, it was a defective diode in the pre-amp.
richidoo
« Reply #2 on: 17 Mar 2025, 08:10 pm »
This happened to me once in a preamp on an AC demo tour. Everybody was raving about it, but when it arrived to me it was making loud intermittent static and crackling noises. I returned it to the mfg/tour host who determined that it was a tube cathode resistor that had cracked (shipping?) but it looked fine externally. He said it was rare but he had seen it before.
Doublej
« Reply #3 on: 17 Mar 2025, 09:05 pm »
Swap the Left and Right interconnect between the preamp and amp. If the static switches sides the problem is either in the preamp or upstream (transport or DAC). If the static stays in the right channel it's either in the amp downstream (speakers).
Go connection by connection until you have identified the faulty component.
novice
  • superbe!
« Reply #4 on: 6 May 2025, 01:53 pm »
I begin at the end of the chain with speakers. If problem swaps to other speaker you know it's not them. Move on to amp, etc. My guess it's the amp and hope OP comments if problem found. If amp has been worked on it could be as simple as a cold solder (diode effect). Or...worse...a bad carbon comp resistor. Can happen if original components left in. Carbons great but can do this exact same thing if bad. They can be sometimes tough to track down.
« Last Edit: 6 May 2025, 03:44 pm by novice »
