W frame OB sub
0 Members and 1 Guest are viewing this topic. Read 1334 times.
tremrej65
W frame OB sub
« on: 12 Mar 2025, 03:55 pm »
I'm looking to build a Double Trouble OB subwoofer.
I see lots of H frame build. None of the W Frame.
I like that the W frame is smaller than the H frame (23.5 inches vs 26).
Question: any difference in sound quality between the two?
Early B.
Re: W frame OB sub
« Reply #1 on: 12 Mar 2025, 04:12 pm »
The W-frame hasn't been recommended for nearly 20 years. I started my OB servo sub journey with a W-frame and replaced it with an H-frame. The H-frame is definitely better, both sonically and structurally.
tremrej65
Re: W frame OB sub
« Reply #2 on: 12 Mar 2025, 11:57 pm »
H frame it is then.
Thanks for sharing your knowledge.
Rejean
Danny Richie
Re: W frame OB sub
« Reply #3 on: 17 Mar 2025, 03:41 am »
The only advantage of the W frame is that it makes it a little shorter.
The W frame also leaves a larger unbraced area in the front. So side panels need to be thicker to compensate for that.
