Bryston BDA3 Firmware - u2020.07a
0 Members and 1 Guest are viewing this topic. Read 2683 times.
Rush2112
« on: 11 Mar 2025, 09:27 pm »
My bryston bda3 is currently at firmware u2020.07a . I beleive there is a newer firmware file for this bda3 . Do i just go the latest release or do i have to update the firmware in 2 steps ? Firmware changelog would be nice . Thanks Darrell
R. Daneel
Re: Bryston BDA3 Firmware - u2020.07a
« Reply #1 on: 12 Mar 2025, 04:52 pm »
Hi Darrell!
Is there a particular reason you want to update the F/W? Typically, this would be done if the device had a problem. Because Bryston DACs are pretty straightforward and don't offer much in terms of selectable filters that could be added with F/W updates, I see no reason in updating it. Also, there is risk involved - if there's a sudden power outage or the cable is disconnected during an update, the device would be due for a repair.
FWIW.
Antun
Rush2112
« Reply #2 on: 13 Mar 2025, 01:01 am »
Usually a firmware update is to add features or fix bugs . Would probably want to see the firmware changelog first and then decide whether or not to update the firmware . Darrell
Blik9
« Reply #3 on: 21 Apr 2025, 09:52 am »
I was stupid and went ahead with the update. Now my BDP3(2016) doesn’t appear in ”my bryston”. The lesson is: If it ain’t broke: Don’t fix it! What to do : (
Stefan_DR3
« Reply #4 on: 27 Apr 2025, 04:56 pm »
I still have the 2018 build on mine but I don't see it on the Bryston downloads page anymore, even though it was confirmed to be the "correct" version for many years.  The 2020 build used to be there as well, but we were told not to use it unless instructed by Bryston.
There are however a couple 2021 builds and a 2022 build in "latest" now:
https://support.bryston.com/downloads/BDA3/BDA3%20Firmware/
Which version did you install that bricked the unit?
There are no release notes so this is very dangerous.  I am thinking these builds are actually intended for the BDA 3.14 since the exact same files are in here: https://support.bryston.com/downloads/BDA-3.14/BDA3.14%20Firmware/
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 27 Apr 2025, 06:28 pm »
Folks - if you have any questions regarding software please email Adam - [email protected]
Blik9
« Reply #6 on: 27 Apr 2025, 08:15 pm »
Adam tried his best, but couldn’t fix it online. It seems I have to ship the BDA to Canada (from Sweden) so Bryston can reprogram it. I can still use it, so I’ll probably wait a while, but I’ll do it. Don’t try this at home : (
R. Daneel
« Reply #7 on: 1 May 2025, 07:18 pm »
Guys, including Blik9,
I've said it many times before and I will say it again - the BDA-series DACs do not benefit from a firmware upgrade. You will not get new features such as digital filter or upsampling options. The DACs were and are designed to work as Bryston intended them to right from the factory. A firmware upgrade with devices of this type can do more harm thank you think due to rudimentary (for a lack of a better word) hardware that handles and stores the firmware data. Firmware, while a form of software, is not 'software' in the way you think it is.
If something goes wrong during a firmware update, a power outage, a connection problem or such, there is a real possibility that you will have destroyed the device. not many factories can do these kinds of repairs - replacing the ROM chip that's almost certainly soldered on the main circuit board with pins that you have to look at with a magnifying glass to see clearly. I believe that Bryston dos board-level repairs so you can probably get your DAC repaired.
Some manufacturers will not do this kind of a repair but they will sell you a complete circuit board and it will cost you dearly. I don't perform firmware updates even on far more sophisticated devices like music workstations (synthesizers), unless absolutely necessary to get the latests sounds, features and/or fixes of previous bugs.
That might be a guideline for you too - if a manufacturer doesn't specify what exactly has been 'fixed' with the new firmware, why would you want to update it? On the other hand, if a manufacturer suggests or instructs you to do so and something goes wrong, then clearly, they have to take the responsibility and they should not pass along the cost of the repair onto you.
That being said, Bryston has been and is run by generous people - Mr. Brian Russel, rest in peace Sir -  and IMHO, their customer support is one of the best in the business so hopefully, they can sort out the problem you are having.
Antun
