Help me choose OB drivers
0 Members and 1 Guest are viewing this topic. Read 3409 times.
in8
« on: 8 Mar 2025, 12:06 am »
I am going to build a pair of Open Baffle speakers . My tweeter is ESS Heil AMT 1 . I am trying to deicide on which one of these 4 woofers too use . SB Audience Bianco -150b350 , Goldwood 215/8 , Goldwood GW 215/8 or Lii Song W15 . If anyone has used these send me a comment on using them . Please do not send me opions if you have not personally used any of these speakers . The Goldwood specs. look great and the price is the best and should I use 2 on each side . Thanks for any info.
Re: Help me choose OB drivers
« Reply #1 on: 8 Mar 2025, 03:58 pm »
You dont want the Alpha15A ?
Qts 1.26
in8
« Reply #2 on: 9 Mar 2025, 04:40 am »
Not very low bass.
« Reply #3 on: 9 Mar 2025, 09:35 am »
In OB all 15" Drivers start attenuate 9dB/octave at 60Hz unless they have a box.
18" seems to be 50Hz.
opnly bafld
« Reply #4 on: 9 Mar 2025, 12:51 pm »
I have a 12" driver that goes lower than the Alpha 15A.
« Last Edit: 9 Mar 2025, 07:54 pm by opnly bafld »
jk@home
« Reply #5 on: 9 Mar 2025, 02:28 pm »
To the OP, I've noticed you have posted this question on multiple forums, with "no bites"  :D
Probably because no one has used your particular 2 way combination. You need to determine and post what frequency response you want to roll the Heils down to, and the (preferably) 1/4 wave distance you can allow to the driver underneath (or above). More than likely, for a 2 way, I would choose a 12" driver. In fact that is what the OEM has on their web site (but with a passive radiator also).
Realistically, you should use a mid range or wide band between the two. I have read the Heils will distort if pushed too low. Unless you add horns to them or double/triple stack em.  :green:
https://community.klipsch.com/index.php?/topic/188177-double-stack-ess-amt-1-with-wings-possible-kit-for-heritage/
If cash is tight (I can relate), for a cheap midrange, I have seen this driver used with the Heils, in a 3 way:
https://www.madisoundspeakerstore.com/special-sale/eminence-beta-8-8-pro-mid-bass-8-ohm/
I actually picked up 4 of these, for the future.
Not to diss this place, but go to the diyaudio forum (where you already have been) and use their search engine. You will get lots of hits regarding the ESS Heil AMT-1s, I get the impression many folks use them there... Full disclosure, I am building a 3 way with Heils, but not "there yet".
« Last Edit: 9 Mar 2025, 06:47 pm by jk@home »
beatboy77
« Reply #6 on: 10 Dec 2025, 11:58 pm »
I personally am a fan of Voxativ for OB designs. Incredible drivers
