Power cord for 7B SST2
0 Members and 1 Guest are viewing this topic. Read 2263 times.
JfTM
« on: 6 Mar 2025, 05:35 pm »
This isn't a cable discussion, honest.
I'm happy with the factory cables.
I'm moving the amplifiers and now need cords with 90 degree NEMA plugs.
Does Bryston sell them? There is nothing on their site.
thorman
Re: Power cord for 7B SST2
« Reply #1 on: 6 Mar 2025, 09:12 pm »
 Why not just order ( from VH Audio ) the Ends you need and install them on your Stock Cords yourself. It is not hard to do and you may open a new world of DIY for yourself.
Ron D
« Reply #2 on: 6 Mar 2025, 09:37 pm »
Pretty sure that Bryston will tell you that the cables they supply are more than adequate for the amplifier in question but  as suggested if you need to make a change DIY can be the least expensive way to go. Maybe next cheapest would be used cables for sale.
Many years ago when I had a pair of squared 7Bs i purchased larger gauge power cables from Pete at Triode wire labs and they worked well for me.
Doublej
Triode Pete
  • www.TriodeWireLabs.com
    • Triode Wire Labs - Affordable Audiophile Cables
« Reply #4 on: 7 Mar 2025, 03:19 pm »
FWIW, I have the "Right Angle Connector Bodies" in-stock that I can fit all Furutech and IeGO mains as well as IEC's...
Pete
