0 Members and 1 Guest are viewing this topic. Read 6372 times.
i would suggest checking out the power-wave series of amps from qsc. they are relatively inexpensive (when priced from pro-audio shops), & make great sub amps, w/damping factors >500. they also run wery cool...http://www.qscaudio.com/doug s.
Quote from: doug s.i would suggest checking out the power-wave series of amps from qsc. they are relatively inexpensive (when priced from pro-audio shops), & make great sub amps, w/damping factors >500. they also run wery cool...http://www.qscaudio.com/doug s.Thanks for the tip, I'll definitely look into it. Seems similar to the Crown K1 & K2 which also would probably be great choices.
