Infinity IRS Beta with new subs and dspNexus 2/8 DSP crossover
0 Members and 1 Guest are viewing this topic. Read 9869 times.
HAL
A customer purchased a dspNexus 2/8 with AK4499EX DAC's is replacing his Infinity IRS Beta speaker servo subs with new passive drivers.  This is similar to the mod done by PS Audio to the IRS Reference V speakers they own.
The customer replaced the 8-12in sub drivers with the model that Paul McGowan suggested.
The dspNexus is replacing the interface box that normally has the active crossover and servo interface.  With Audio Weaver setup a new DSP crossover to make measurements with REW.  Measured the sub column and Beta speakers.   Then made one more measurement at his listening seat.  Generated the correction filters needed loaded them into the Audio Weaver block diagram.
He is listening to the results with his system now.  He will be doing further measurements of the speakers and room to complete the crossover design with speaker correction and room bass management.
Pictures of his setup once he take it.
HAL
Here is the Infinity IRS Beta setup with the dspNexus 2/8 running the updated sub towers and crossover to the Betas.  This replaced the Infinity Controller system originally in use.
Crockett
Very nice system. I have a pair of the Infinity Beta 50s and like them a lot. Probably upgrade in the future though.
racerxnet
Rich,
As you are aware, I am refurbishing my G2 bass towers. This appears to be very similar to my needs. Can you expand upon the parts needed. I am open to all options at this time.
Mark
HAL
Mark,
I was not involved with the IRS Beta sub replacement work, so have no information.
The owner was looking at this video and contacted Paul McGowan about the sub drivers to use.  This is what he sent me to look at for DSP crossover ideas:
https://www.psaudio.com/blogs/ask-paul/infinity-irsv-woofers-and-selling-this-one-of-a-kind-beauty
He did the modifications to add the new 12in sub drivers
I would suggest talking to Paul as he might have been involved with the G2 speaker design.
Rich
