Frequency response listing...
Kray
« on: 26 Feb 2025, 05:26 pm »
Does anyone know what the +/- is on the frequency response that Louis list on his speakers?
i.e. 40Hz - 20Khz, is the 40Hz +/- 3db? 6db?
« Last Edit: 26 Feb 2025, 06:55 pm by Kray »
seikosha
Re: Frequency response listing...
« Reply #1 on: 26 Feb 2025, 06:06 pm »
I’ve actually did some crude in room measurements in the past and my data corresponded to about a -5 decibels on his bottom measurement.
AvsFan
« Reply #2 on: 10 Apr 2025, 02:43 pm »
You! I used to conversate with both of you! You guys still around?
« Reply #3 on: 11 Apr 2025, 08:54 pm »
Usually +/- 3dB means -1.5/+1.5 IMO.
But I could be wrong.
JassyHong
« Reply #4 on: 20 Jun 2026, 11:58 am »
I've found that small changes in speaker placement and room acoustics can sometimes make a bigger difference than expected. It's always worth experimenting with positioning before making any major hardware changes.
« Reply #5 on: 20 Jun 2026, 05:46 pm »
Welcome to AC  :thumb:
Maybe you would like this speaker setting topic from 2009.
Master Set speaker adjustment:
https://www.audiocircle.com/index.php?topic=65908.0
Master Set Revisited - 2019
https://www.audiocircle.com/index.php?topic=163879.0
