0 Members and 1 Guest are viewing this topic. Read 13643 times.
Mark Baker of Origin Live believes that if the tonearm is well designed and well built, Resonant Frequency is virtually a non-issue. Much ado about nothing.https://www.originlive.com/hi-fi/tonearm/(see bottom of the page)I own 2 Origin Live arms and have used carts that according to the RF calculator, are not a good match. No problem at all. So I concur with his view. I'd say just give it a try. If it sounds good, it is good!
Sounds like your having fun and really enjoying getting back into vinyl Larry. Not sure how I missed this thread earlier, did you find an auto-lifter you like ? I can recommend the Q Up unit, been using one on my TD 160 Mk II for a couple of years now. Inexpensive, easy to install & set up, and when I had a couple of early minor setup issues the support was spot on. https://www.thequp.com/ A friend subsequently tried one on his Clearaudio unit and has been very happy as well. Keep us posted, and keep 'em spinning Sir.JD
