Hey Everybody!
0 Members and 1 Guest are viewing this topic. Read 1305 times.
MisterP007
  • Hey Everybody from Tunbridge Wells
Hey Everybody!
« on: 12 Feb 2025, 10:47 am »
I need to start posting on here so I thought I would start with my system and a question or two:
Sources:
Digital: Roon run from an iPad via IBM mini PC, output to Cambridge Audio 851D DAC via USB.
Vinyl: Manticore Mantra Turntable (heavily modified) with Rega RB250 arm and Dynavector DV10x-4 Cartridge via Project Phono Box S2 Phono Stage
Amplification: Advantage S2 Pre-amp, Advantage S150 stereo power amp (these are Swedish made by Mike Bladelius who used to work with Nelson Pass, 150W per channel pure class A monsters that can deliver 51Amps of current). Fully balanced devices cabled from the Cambridge DAC with XLR's.
Speakers: ProAc DT8 bi-wired with Chord Rumour X cables. I have been long awaiting Danny coming up with an improvement kit for these, but nothing yet.
BK Electronics XXLS400 Sub Woofer (long throw 12" sub good down to 15hz with 400w class A/B plate amp). Only really use this for a party or a big movie as the ProAcs and good down to 28hz on their own.
Overall sound impressions: Great detail retrieval and famous ProAc imaging and mid range. Staggering dynamics (mainly because of the ridiculous headroom available with the Amp 150w into 8 ohm, 300 into 4 ohm and 600 into 2 ohm, 1800VA torroid and 120000mf of caps on the power supply). The speakers at around £3000 are a huge bargain in the UK (mine were ex display at £980 so even more of a bargain). The system plays nice at low volume but really gets moving when cranked up.
All of my gear is bought used or ex-display to keep the cost down (cost me about £3250 used vs new price of £13000).
If you can find these Amps in the US buy them without hesitation. Mike Bladelius designed a lot of Threshold, Classe and Pass Labs stuff in his past.
Work to be Done: I am planning a crossover upgrade on the speakers and an upgrade of components in the DAC (output stage, power supply and clock) when time and cash allows.
Bye for now.
Phil A
Re: Hey Everybody!
« Reply #1 on: 12 Feb 2025, 01:47 pm »
Welcome to AC!
Re: Hey Everybody!
« Reply #2 on: 15 Feb 2025, 03:33 pm »
Greetings & Welcome to AC   :thumb:
Re: Hey Everybody!
« Reply #3 on: 15 Feb 2025, 04:26 pm »
What is the room like?  (The 2nd most important component in your system.)
toocool4
Re: Hey Everybody!
« Reply #4 on: 15 Feb 2025, 05:31 pm »
Welcome to AudioCircle MisterP007
Re: Hey Everybody!
« Reply #5 on: 20 Feb 2025, 04:56 pm »
Norman Tracy
    • Audio Crafters Guild
Re: Hey Everybody!
« Reply #6 on: 21 Feb 2025, 12:42 am »
Welcome to AudioCircle MisterP007, that is a very nicely sorted system.
My impression is ProAc has low key distribution in North America. Looks like we have The Sound Organisation in Arlington Texas for the entire USA. The original Tablette made a big splash in its day on the way towards being a classic. As a fan of little monitors driven by big amps I would love to hear the current Tablette 10 Signature, or the DT8, or while I am wishing the K10!
Point is you may be waiting awhile before a set of DT8 make its way to GR Research for the Danny treatment. I would suggest for an upgrade to your DT8 look into better capacitors including if you find any electrolytics converting those to polypropylene plastic film types. Then if any of the inductors are iron core types replace with air cores. Then upgrade resistors. In this scenario keep the electrical values matching those chosen by ProAc's designer replacing with better parts of identical values. When you're ready to start posting photos of the existing crossovers in the Enclosures circle is a good start, assuming you want lots of free advice on how to spend your money.  :wink:
