Qobuz Connect?
cleeds
Qobuz Connect?
« on: 4 Feb 2025, 07:43 pm »
Qobuz has revealed its Qobuz Connect feature is in beta and that many manufacturers are working on integrating the app into their streamer software. Could James Tanner please tell us if Bryston is working on Qobuz Connect? Apps such as this seem to be the future of streaming.
EvanMcC
  • Bryston, Dynaudio & Torus
Re: Qobuz Connect?
« Reply #1 on: 15 May 2025, 04:22 pm »
Bump.........
https://www.qobuz.com/ca-en/connect
Would love to know if this is coming to the BR-20. Would like to see this added.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Qobuz Connect?
« Reply #2 on: 15 May 2025, 04:29 pm »
I know the software guys are getting the licenses.
james
EvanMcC
Re: Qobuz Connect?
« Reply #3 on: 15 May 2025, 04:31 pm »
Awesome!
Sounds like a good start.
Evan
jobiwon
Re: Qobuz Connect?
« Reply #4 on: 15 May 2025, 06:07 pm »
I came here to start a thread with this very question.
So do we think it would appear only for the BR20 or also include discontinued products that run MM (BDP 3, pi etc).
BeeJay
Re: Qobuz Connect?
« Reply #5 on: 15 May 2025, 06:12 pm »
james
Hi James, would these be the same 'guys' working on Tidal Connect?
Barry
alanford69
Re: Qobuz Connect?
« Reply #6 on: 15 May 2025, 07:04 pm »
Hopefully they will not end up like those working on OS3 :duh: :duh:
cmccaul
Re: Qobuz Connect?
« Reply #7 on: 15 May 2025, 07:55 pm »
I'm still patiently waiting for OS3...  :popcorn:
Stefan_DR3
Re: Qobuz Connect?
« Reply #8 on: 16 May 2025, 02:32 pm »
Awww jinxed it!  You guys shouldn’t have mentioned OS3.
This thread will be devolving shortly…  :popcorn:
drummermitchell
Re: Qobuz Connect?
« Reply #9 on: 17 May 2025, 01:02 am »
Kansas……..Dust in the wind………
drummermitchell
Re: Qobuz Connect?
« Reply #10 on: 17 May 2025, 01:03 am »
Ethan Hunt…..
This Tape will self destruct 15 …………14….13……12………Pooof.
Rod_S
Re: Qobuz Connect?
« Reply #11 on: 19 May 2025, 08:04 pm »
What about compatibility with the BDP's i.e. BDP-2 and BDP-3?
Stefan_DR3
Re: Qobuz Connect?
« Reply #12 on: 19 May 2025, 08:06 pm »
It’s expected. I am told they are developing on a BDP2 so I would expect it to be compatible with BDP2 and newer.
Rod_S
Re: Qobuz Connect?
« Reply #13 on: 19 May 2025, 08:43 pm »
I'm contemplating subscribing to a streaming service for the 1st time and looking at the various options out there and also what my BDP-2 can and can't connect with. What caught my interest was seeing a few albums from bands I like being released in Dolby Atmos only on streaming and not on physical media. Researching a bit it seems Apple Music is a source for the Atmos mixes but the BDP-2 is not cable of accessing Apple Music. Is that correct?
jobiwon
Re: Qobuz Connect?
« Reply #14 on: 19 May 2025, 09:08 pm »
Tidal and Qobuz are the 2 primary services I am aware of.
Rod_S
Re: Qobuz Connect?
« Reply #15 on: 20 May 2025, 02:12 am »
I found out apparently Tidal supports Dolby Atmos, as does Amazon Music, has anyone tried streaming an Atmos albums or even singles thru a BFP-2 or BDP-3 from Tidal and if so did it pass the Atmos mix through?
Stefan_DR3
Re: Qobuz Connect?
« Reply #16 on: 18 Jun 2025, 12:10 am »
Pass Atmos through to what?  The BDP is a 2-channel device and has no HDMI output or Dolby decoder. Furthermore the software does not allow you to select Dolby streams, only FLAC, MP3, etc.
Here’s a list. You can filter by Atmos support.
https://tidal.com/supported-devices
« Last Edit: 28 Jun 2025, 11:51 pm by Stefan_DR3 »
Mr.Vertigo
Re: Qobuz Connect?
« Reply #17 on: 28 Jun 2025, 10:37 am »
I am so desperately waiting for Qobuz Connect to replace MM for the BDA 3.14  :bowdown:
Rod_S
Re: Qobuz Connect?
« Reply #18 on: 4 Jul 2025, 12:42 am »
Ah yes, very good point. Although the BDP does recognize a multi-channel FLAC file, as you state, the unit is a 2 channel output device. That's the piece I had forgotten about, I knew for years it correctly sees multi-channel sources and identifies the number of channels but can only output the left and right channel from those files. So it makes sense it would behave the same for a streamed source from Qobuz, etc. vs one being read from a USB thumb drive or a NAS.
Regarding no Dolby decoder, I'm not sure it would matter and wouldn't need one providing the downstream device does have one like a home theater receiver or surround sound processor.
EvanMcC
Re: Qobuz Connect?
« Reply #19 on: 3 Sep 2025, 07:19 pm »
@James - Bumping up this topic - it's been a few months and *many* other companies have launched Qobuz Connect. Not to mention Tidal Connect which has been around a long time.
Bryston I am certain you're doing what you can, but - the software side of the business really needs to speed up.
Especially when it comes to features on such an expensive unit (ex. BR-20).
How have Wiim and other cheap brands done it so quickly?
Please & thanks.
Happy to beta test it with you too!
