Bryston 4B3 green status light shuts off in one minute
wdizard
I am having a problem . My green status light on the bottom of back side shuts off after one minute.
wdizard
Re: Bryston 4B3 green status light shuts off in one minute
« Reply #1 on: 2 Feb 2025, 05:15 pm »
Does Seattle Washington have a service center for Bryston products?
Ron D
« Reply #2 on: 2 Feb 2025, 05:28 pm »
If you go to their website you will find out that US based customers should contact their US service location located in NY state.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 2 Feb 2025, 05:44 pm »
Check with Mike first - is the amp shutting off?
[email protected]
wdizard
« Reply #4 on: 2 Feb 2025, 05:57 pm »
Yes Sir the amp shuts off by itself
« Reply #5 on: 2 Feb 2025, 05:58 pm »
OK I am sure Mike can help - it's a new one on me?
james
wdizard
« Reply #6 on: 2 Feb 2025, 06:02 pm »
I just sent a e mail to Mike.
wdizard
« Reply #7 on: 2 Feb 2025, 06:09 pm »
Actually the front light around the switch stays on it just is not producing sound
wdizard
« Reply #8 on: 2 Feb 2025, 06:18 pm »
The green status light stays on for about eight seconds then goes off and it never sends sound out at all but the two blue lights next to the switch on the front side stay on.
« Reply #9 on: 2 Feb 2025, 07:11 pm »
And it was working fine before?
wdizard
« Reply #10 on: 2 Feb 2025, 08:13 pm »
Yes I have had this for two years with no problem.
wdizard
« Reply #11 on: 2 Feb 2025, 10:06 pm »
GREAT NEWS! I just flipped the small chrome toggle switch on the far right of the top of the rear panel and that fixed it!  I flipped it down where it says single ended
« Reply #12 on: 2 Feb 2025, 10:41 pm »
GREAT !!!
