6B SST and Focal Diablo Utopia Colour Evo
0 Members and 1 Guest are viewing this topic. Read 4181 times.
cameraman
« on: 1 Feb 2025, 03:42 am »
I currently use a 6B SST to power three Dynaudio contour 20's in my family room. For now I am replacing the FL and FR Dynaudio mains with Focal Diablo Utopia Colour Evo speakers. When my wallet recovers, I may replace the third Contour 20 used as a center channel with a Focal Diablo Utopia. I use a pair or subwoofers with the mains so they won't need to handle subwoofer duty. I plan on keeping the single Dynaudio CC for now though I know it may not blend well with the Focal's. I have a dedicated theater for critical movie watching so not too worried about the mismatch for now. That may change once I get everything set up.
Two channel is the priority. I use an Anthem STR preamp for two channel and put the STR in bypass mode to share the mains and subwoofers for TV with a Denon AVR.
I assume the 6B SST will work well but with this pricy speaker change want to confirm.
I also have a 7B ST and a 4B ST in another room I can repurpose but assume the 6B SST is still my best option.
Thanks.
mv038856
Re: 6B SST and Focal Diablo Utopia Colour Evo
« Reply #1 on: 6 Feb 2025, 04:06 pm »
I cannot comment on the speakers as I never have heard them, but I love the 6B SST!
I also felt that the SST has been a big step from the ST line.
Even the late ST amps, like the 9B ST, were a big step forward, IMHO.
At one point, I had a 4B ST and a 9B ST in my system, and to my ears, the 9B ST clearly sounded better than the 4B ST, all other components identical.
Markus
cameraman
« Reply #2 on: 6 Feb 2025, 05:54 pm »
Markus
I expect the 6B SST will work great. I've also decided to go ahead and order a third Diablo for center channel use while in Home Theater Bypass mode on my preamp. This has worked nicely on my current Dynaudio Contour 20 three speaker configuration. Two channel is the priority but I do like having three identical speakers for FL, CC, FR for Home Theater use. Thank you.
mv038856
« Reply #3 on: 6 Feb 2025, 06:49 pm »
I am convinced that it will work great!
I am currently using three 6B SSTs in my home theater, one of them for the three identical Dynaudio Contour S 1.4 behind the acoustically transparent screen. So we are thinking along the same line, I think. ;)
cameraman
« Reply #4 on: 8 Jul 2025, 07:07 pm »
I went ahead with a 3rd Focal Diablo to use as a Center Channel while my Anthem STR stereo preamp is in Home Theater Bypass mode. The Focal Viva stand turned out to be the perfect height for the center channel.
The Bryston 6BSST is shared between the Anthem STR and Denon AVR and powers all three Focal Diablo's. I'm using a pro amp for the two subwoofers but might use a couple Bryston amps that aren't getting much use in a third room.
Any issue in using a 7BST to power one sub and bridge a 4BST to power the other or would a single 4BST be enough to power my pair of Scan-Speak 32W/4878T Revelator's, each in 1.5 cubic foot sealed box's? I'm using a QSC PLD4.2 bridged for 2-channel now and it works well other than making sure the DSP is not engaged. Thank you.
https://www.madisoundspeakerstore.com/approx-12-subwoofers/scan-speak-32w/4878t-revelator-13-subwoofer/
JCarney
« Reply #5 on: 9 Jul 2025, 02:17 am »
Congrats on the new speakers. Nice set up.
JCarney
Altitude Fidelity
    • Altitude Fidelity
« Reply #6 on: 13 Nov 2025, 03:40 pm »
That setup looks sweet. Enjoy!
