MM startup script
0 Members and 1 Guest are viewing this topic. Read 1786 times.
cmccaul
MM startup script
« on: 26 Jan 2025, 11:49 pm »
Is there any way to add/modify squeezelite parameters through the startup script?  I currently have "/bin/bservices/Squeezelite\ start" in the script after squeezelite disappeared from the services menu.  I'd really like to increase the default buffer size.
  • The Demo is Everything!
    • http://www.bryston.com
Re: MM startup script
« Reply #1 on: 27 Jan 2025, 11:50 am »
Hi - email Chris on this - [email protected]
cmccaul
« Reply #2 on: 27 Jan 2025, 01:51 pm »
Will do.  Thanks.
