Kismet with Stereo Rels
0 Members and 2 Guests are viewing this topic. Read 7185 times.
bacchus1234
« on: 26 Jan 2025, 07:58 pm »
Does anyone know if the negative terminals are actually true ground?
I added an additional Rel sub via high-level connection and have them wired the same as my speakers with the red and yellow wires on the left channel positive terminal and the black on the negative with this being mirrored on the right channel.
Rel suggests that the black wires should go to a designated ground point OR to a chassis screw OR to just let them “float”. The Kismet has neither of those first two options.
Finally, if those negative terminals are ground , then should I connect both black wires to a single negative or keep them the way that I currently have them set up now?
opnly bafld
Re: Kismet with Stereo Rels
« Reply #1 on: 26 Jan 2025, 08:32 pm »
When I had 2 REL's they were wired like you have them now, red and yellow to + and black to -  one subwoofer per channel.
If they aren't humming or making noise you are good.
bacchus1234
« Reply #2 on: 27 Jan 2025, 11:07 pm »
Thank you!
