BDA-3 DAC very low output
thebiglebowski
« on: 24 Jan 2025, 11:08 pm »
I have a 4.5 yr old BDA-3 and having not used it for a while have found that the output of the RCA & XLR is very low. The volume needs to be almost at max before anything is audible.
Have tested on two amps, a Devialet and Sugden A21a2 and both are the same.
Did notice that in the firmware instruction it has screenshot of the web interface with a volume slider and in one of the appnotes it says an init will reset the "vol" parameters so it needs to be manually set to "vol=255" after.
Is it possible that being not used for so long it has reset itself?
thebiglebowski
Re: BDA-3 DAC very low output
« Reply #1 on: 24 Jan 2025, 11:48 pm »
The volume slider on the web interface was set to '25' sliding it to 100 has fixed.
Does changing the volume/output level get saved to the config if done via the web interface?
thebiglebowski
« Reply #2 on: 1 Feb 2025, 10:13 am »
Is there a way of making the volume/output level permanent as it's reverting back to 25% after a reboot or when powered off/on?
