Introduction Copland / B&W / Bluesound Node
0 Members and 1 Guest are viewing this topic. Read 762 times.
philhjobim
« on: 21 Jan 2025, 11:24 pm »
Hi,
I put together a system in 2001 with Copland CSA28 hybrid amp, Micromega CD player, B&W CDM1SE monitors on stands, and Transparent magic cables.
It has done me well for 23 years, with two changes of triode valves, and a move from CD player to Bluesound node stream Qobuz into Beresford Caiman DAC.
I built an ACI Titan 250W sub because of its renowned ability for the twin 12dB filters to allow it to sit seamlessly under the monitors and extend their range a couple of octaves, which it does beautifully.
I came here chasing schematics for the sub because a power fluctuation has blown something.  Hopefully its just the power supply.
All the best
Phil UK
Phil A
Re: Introduction Copland / B&W / Bluesound Node
« Reply #1 on: 22 Jan 2025, 04:36 am »
Welcome to AC!  You can look at places like hifiengine to see if they have the schematic you are searching for.
« Reply #2 on: 22 Jan 2025, 04:22 pm »
Cheers & Welcome to AC Phil   :thumb:
