Klipsch 404c upgrade questions
0 Members and 1 Guest are viewing this topic. Read 1365 times.
willief23
« on: 18 Jan 2025, 07:56 pm »
Hi,
Im about to upgrade my Klipsch 404c speaker.  Does anyone know the max size board that will fit in there?  I will be using bigger caps etc so wanted to know what size boards fit inside the speaker. Im assuming its two or three smaller boards instead of one big board.  I upgraded my 600m years ago and loved the way it turned out so time to upgrade the center speaker.  I plan on using Elon (ezeescrossovers) again for putting the crossover together.
Will
Danny Richie
    • http://www.gr-research.com
Re: Klipsch 404c upgrade questions
« Reply #1 on: 21 Jan 2025, 11:43 pm »
Hi,
Will
Measure the internal space to see what you have. Also, make it small enough to slide through a woofer hole with the parts mounted on it.
E-Zee
    • Diy speaker resources and crossover assembly services
« Reply #2 on: 25 Jan 2025, 09:12 pm »
Will,
I know this wasn't the question,  but I cant help but sharing this thought for your consideration.  If you haven't already bought the upgrade kit, and you have adequate space around your center for a large model,  I have seen many of the larger RP- series center channels very well priced recently.  Maybe check  slickdeals.net.      >tech deals>audio.
My though would be that if you tried to sell your 404-c locally,  even for a little under $200, and we're able to get into a larger version for close to or even under $300, you would still have options of doing a crossover upgrade but in that larger platform.  You might be able to swap to a larger center at a net cost of $150 to $200. Better now then later.  Then get the kit for your new replacement.
If you already bought your kit,  then please forgive and ignore me.
Elon
[email protected]
For anyone else looking at klipsch the rp-500m II is on sale $269,  and the RP-600m II at $299.  I wouldn't turn down either of those, both excellent with a crossover upgrade kit
