Triode Wire Labs 2025 Show Schedule
Triode Pete
« on: 18 Jan 2025, 07:09 pm »
https://floridaaudioexpo.com
Triode Wire Labs will be teaming up with BorderPatrol Audio Electronics, Living Voice Loudspeakers and Innuos for the first show of 2025, The Florida International Audio Expo Feb 21 - 23, 2025 in Tampa Florida, at a new larger venue, The Sheraton Tampa Brandon!
We will be in the high visibility Room 227 with an assortment of audio goodies!
Come join us for some high level audio entertainment and a libation of your choosing!
See you there,
Pete
BobM
Re: Triode Wire Labs 2025 Show Schedule
« Reply #1 on: 18 Jan 2025, 10:32 pm »
Laura and I will be there on Friday and bringing some friends along.
Triode Pete
« Reply #2 on: 19 Jan 2025, 03:42 pm »
 :thumb:
Triode Pete
« Reply #3 on: 8 Nov 2025, 04:25 pm »
https://www.capitalaudiofest.com/
Triode Wire Labs will be exhibiting in TWO Rooms at the upcoming Capital AudioFest show, November 14-16, at the Hilton Rockville in Rockville, Maryland.
In Room 316, we will be teaming up with BorderPatrol Audio Electronics, Living Voice Loudspeakers and Innuos. Gary Dews, from BorderPatrol will have the Global Debut on his newest DAC, the ZOLA DAC. The DAC features the Analog devices AD1865 chip (often called the analogue chip) in non-oversampling, no digital filtering (NOS) mode. Inputs for USB, COAX S/PDIF and TOSLINK. A BNC S/PDIF input is also provided. The DAC features a tube output stage that uses a 5687 double triode. An E182CC/7044/7119 double triode can also be used, as can a 12BH7 with an adapter. The DAC has fully independent power supplies to the digital and analogue sections. Both supplies feature tube rectification. The high voltage tube supply uses choke input filtering. The casework, other than the aluminum front panel, is made from copper. The DAC will replay files up to 32/384kHz via USB, 24/192kHz via COAX SPDIF/BNC and 24/96 via TOSLINK.
In Room 661, we will be teaming up with Volti Audio. Greg Roberts, from Volti Audio, will be bringing his world-renowned horn loudspeakers with amplification from Cary Audio and a DAC from Mojo Audio.
I hope to see many of you there!
Pete
