4b vs 7b question
amdan
4b vs 7b question
« on: 10 Jan 2025, 12:02 pm »
Hi - I understand that when bridged, the 4B3 outputs 900 watts vs the 7B3's 600 watts. I assume there is some advantage in using a couple of 7B3s rather than two bridged 4B3s. What is the advantage? Also, how big a difference is there? I already own a 4B and it would be cheaper for me to get another rather than replace with two 7Bs.
Thanks in advance.
zeeman
Re: 4b vs 7b question
« Reply #1 on: 10 Jan 2025, 03:26 pm »
Stereo amps like the 4B lose damping factor and low impedance stability when you bridge them.  Bridging is a relic of pro use where the techs would need to adjust the # of channels based on the venue, so having bridgeable amps made sense.  A pair of 7B's is a far better option at the same price as 2 4B's.
Markwatkiss
« Reply #2 on: 10 Jan 2025, 03:39 pm »
7B's would be the way to go.
OldAudioGuy
« Reply #3 on: 10 Jan 2025, 04:15 pm »
I just made this exact upgrade from 1x 4BSST to 2X 7B3.  Very happy with the $ spent to do so.  If you've got current hungry speakers that are inefficient / hard to drive, its well worth going to the 7B mono's, IMHO.
Brent
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 14 Jan 2025, 12:05 pm »
When you bridge an amplifier (4B) it 'sees' 1/2 of the impedance it does in Stereo. So depending on the difficulty of the load - the speaker - the amplifier may current limit.
The mono 7B would not have this issue so much depends on the speaker chosen.
james
amdan
« Reply #5 on: 17 Jan 2025, 04:05 am »
Thank you, Zeeman and James. Given this, bridging won't work for me. Speakers are B&W 802N.
Stefan_DR3
« Reply #6 on: 18 Jan 2025, 05:05 am »
You want to look into bi-amping, rather.
