0 Members and 1 Guest are viewing this topic. Read 7337 times.
Scott,you wound up making a tube trap out of sonotube? Never thought about that before, how'd it turn out? How many holes did you wind up drilling in it?
Wow... if you decide to stop writing software you would make a good writer.
Hope it all works out in the end.
Haven't done it, yet. Tomorrow, after the holiday, I plan to start calling around for 24" sonotube.
I'm not sure I understand the theory behind the sonotube and drilling holes in it. What are the holes for? Are you filling it with insulation?
http://users.net1plus.com/scottm/room.htmUpdated with the next part of the Saga of the Room from Hell
I didn't realize it yesterday, but the Handbook of Acoustics has a section that details frequency response for hole spacings for different types of absorbers.
This isn't as relevant as I thought...
If there's a larger book, let me know the title. While I like the book I have, I don't think it goes into enough detail.
For instance, diffusion apparently helps even out the sound in a room, but is diffusion beneficial for a room that strictly designed for listening? I fear the only way I'm going to find out the answer is to put diffusion into my room and measure the results and/or listen for results.
Hope your room goes more smoothly in the future. Built a custom room myself last summer and I'm no carpenter or electrician or drywaller but it got done and is the best sound I've heard. Only bad thing I did was stick the power screwdriver bit through my thumb as I slipped while installing resilient channel. Wish I knew how much a good room could help before. You'll be impressed when you're done is my point and hopefully forget(yeah right) the ordeal. Great story though!
