0 Members and 2 Guests are viewing this topic. Read 8741 times.
A DAC though would be IMHO a choice over a streamer. charles
I helped a friend pick out a DAC/Streamer. We looked at last years Blue Sound Node and it sounded muddy in comparison to the Lumin D3 that he ended up buying. However the cost difference was about 1900 dollars. We were not impressed with the DAC in the BSN. The Lumin had much more detail, was neutral sounding and more musical.Just some food for thought.
Are you using an outboard dac with the Bluesound, and if so which one? That might be a deciding factor. I think the Bluesound is a very reasonable streamer using the digital output to an outboard dac, but the onboard dac is quite limiting.
....The combined budget will be pretty modest but I could see myself with something like the DVA digital pre in the system. And if so would a BS streamer be holding it back.
...The caveat with the digital preamp is it really sounds best when used with the differential (XLR) outputs... Something to think about if your amplifier(s) don't have XLR inputs and you're not in a position to replace...
If I can chime in, I've had wonderful results playing around with a Bluesound Node 2i customized with a DC power supply and a 5v linear power, which is easy to do........
Thanks for the info, can you provide further details? Which ones do you use? Links would be great!Thanks...John
The Eversolo's are getting good reviews, becoming very popular,
I am, however, interested in the LPS upgrade for the Vault that will remain in the system, at least until adding storage to the A8.
"in case others interpreted Crad's comment the way I initially did. Sounds like adding The Beatnik linear power supply to the Betnik is not such a great idea."
