How big a Kallax would you trust?
0 Members and 1 Guest are viewing this topic. Read 1472 times.
abernardi
« on: 8 Dec 2024, 08:38 am »
I'm thinking of getting the big Kallax for my records.  It's 5X5 (25) cubes and stands 71".  You can put it on a steel footer which raises it another 7".
https://www.ikea.com/us/en/p/kallax-shelf-unit-black-brown-70301542/
It looks precarious to me.  Anyone have experience with this?
toocool4
Re: How big a Kallax would you trust?
« Reply #1 on: 8 Dec 2024, 09:18 am »
I have friends that use the 5 x 5 ones without issues, none of them use the steel footers. There is a friend that uses the steel footers under a 4 x 4 Kallax unit. I personally use the 4 x 4 unit but no steel footers.
If I did buy a 5 x 5 units, I would personally just put it straight on the floor like I have done with the 4 x 4 units.
Photon46
« Reply #2 on: 8 Dec 2024, 11:52 am »
I've used two 5x5 units and a 2x5 unit stuffed to the max with vinyl for many years without issue. They sit directly on the floor, no footers.
GeneS
« Reply #3 on: 8 Dec 2024, 01:53 pm »
  I currently have a 2.5 x 5 unit (8 cubes) stacked on top of a 5 x 5 (16 cubes) and never had a problem. I’ve had it for years, and there are no signs of sagging or fatigue. I have shims on the bottom because my floor isn’t level :roll:, but other than that, they sit directly on the floor.
twitch54
« Reply #4 on: 8 Dec 2024, 05:47 pm »
If you look at the picture you'll see it has wall anchoring brackets in the upper corners, you'll be fine .....
abernardi
« Reply #5 on: 9 Dec 2024, 03:45 am »
Thanks everyone for your input.  I feel better now about using them!
viggen
« Reply #6 on: 9 Dec 2024, 11:48 pm »
I placed a 20gallon fish tank on top of an expedit.  i added L brackets in every corner.
