Hi from audio hobbyist becoming an enthusiast
0 Members and 1 Guest are viewing this topic. Read 894 times.
Luvchampagne
« on: 6 Dec 2024, 05:34 am »
Hi
I came across AC while searching for speakers with Purifi drivers and went down the rabbit hole of reading the many posts in the Salk owner forum and now looking for a Salk Bepure 2 or something similar.
Look forward to learning from other members as I keep learning myself.
Current setup is
Mcintosh Mc7270 x 2
Yamaha MX-D1
Krell HTS 7.1
SMSL SU9
Apple laptop for source
Aerial Acoustics 8
M&K S1-C
M&K MX700 x 2
Sunfire HRS10
Re: Hi from audio hobbyist becoming an enthusiast
« Reply #1 on: 6 Dec 2024, 11:11 am »
Welcome to AC  :thumb:
« Reply #2 on: 6 Dec 2024, 02:18 pm »
I had active Buchardt A500SE monitors which used two 6.5 inch Purifi mid/woofers (one forward firing and one rearward firing) with a 0.75 inch tweeter in a wave guide.  Inside were four 150 watt amps (the front Purifi was wired as a midrange and a woofer).  It connected wirelessly or via XLR.  It had "master tuning" options and in wireless mode also had room EQ.  It was rated in-room down to 25 Hz.  A wonderful all around speaker.  The A500SE has been replaced with the A10, which deletes the rear driver but is less expensive.
Active designs (used by studio professionals) have a number of inherent acoustic advantages over passive (typical consumer) designs.  The crossover is low voltage (before the amps) so it can be more precisely designed and a DAC/room EQ can be incorporated.  The designer picks the amp and matches it to the driver.  The amp "sees" the driver load so is more reactive to the driver.  Bass typically goes lower and dynamics are improved.
Luvchampagne
« Reply #3 on: 6 Dec 2024, 03:29 pm »
Thank you for your reply. Did you have the hiss at low volume that some people complain about? It's one of those things that are probably inaudible at listening volumes but once you know it's there, you listen for it and in quiet passages it drives you crazy.
Luvchampagne
« Reply #4 on: 6 Dec 2024, 03:30 pm »
Thank you very much. I look forward to learning and participating on the forums.
Phil A
« Reply #5 on: 6 Dec 2024, 10:56 pm »
Welcome!
« Reply #6 on: 6 Dec 2024, 10:57 pm »
Greetings & Welcome to AC   :thumb:
