FU-19 (FM30, 829B) Single-Ended Tube Amp!
ketchup
Re: FU-19 (FM30, 829B) Single-Ended Tube Amp!
« Reply #260 on: 16 Dec 2025, 03:38 am »
I did a little poking around inside my amp today. I was able to significantly tighten up the output tube socket contacts. The tubes pushed in with little resistance in stock form and felt very loose. They're now pretty tight. Not quite as tight as my Rogue M180 sockets, but close.
I also changed the cheesy anode connectors and caps. The factory clips were very loose and cheap feeling. When doing this, I got a good look at the blue anode wires and I'm pretty sure that they're Teflon insulated. I forgot to measure them, but they're probably around 18-20awg.
Premnath
« Reply #261 on: 1 Feb 2026, 06:43 am »
I am based in India. This is my first post here.
I only listen to vinyl
My rig is
EMT 930 with 139 phono and TSD 15 cartridge
ThoressF2A, Sunvalley 300, HFSA01
Axiom 80 drivers in Goodman designed cabinet with ARU
My room is approx 400 sq feet. Average listening level is 85-80 db with peaks hitting 90-95 db
Mainly into jazz, Indian classical( vocals) , classic rock and fusion
Axiom 80 can handle max 12 watts. It’s 96 db efficient. It goes down easily to 35 hz at my place. But SPL is limited.
Of the 3 amps i own, HFSA 01 appears to have the best synergy. It has drive, resolution, tone and good bass.
I was wondering if the FM30 or a Elekit 8900 or a Paul Birkeland 2a3 or a Almarro EL84 SEP be worth looking at?
« Reply #262 on: 1 Feb 2026, 09:26 am »
My rig is
The FM30/829B are the best value $/sound quality I have seen in decades.
How many Watts do you want ?
Other option are the Wright Royale 7W $1485, nice Transformers, not small.
https://wrightaudioarts.com/Royale-SE-Power-Amplifier/
Premnath
« Reply #263 on: 1 Feb 2026, 09:56 am »
I think Wright Audio only offers 120v. Being in India i need a 240v 50hz model.
Can the FM30 amp be played at 240v 50hz? They seem to have a universal voltage transformer.
opnly bafld
« Reply #264 on: 1 Feb 2026, 07:34 pm »
Welcome Premnath
My rig is
What is your budget?
Can you or someone you know put together a kit?
« Reply #265 on: 1 Feb 2026, 08:58 pm »
I got the single ended parallel version of this amp and I realized the other day that the tubes I run in it are more expensive than the amp itself, hahaha.
Premnath
« Reply #266 on: 2 Feb 2026, 02:54 am »
Thanks opnly bafld
I can extend upto USD 8000, if needed. But my experience has been spending more doesn’t necessarily mean better SQ. Synergy I feel is far more critical.
Am not a DIY guy. But know people who can put it together
« Reply #267 on: 2 Feb 2026, 09:38 pm »
There is no universal Transformer, it would need to have six primary input windings 100, 120, 127, 220, 230, 240V, I think they dont offer it, only 110V 220V. Some UK brands have 115V + 115V to 230V operation.
opnly bafld
« Reply #268 on: 3 Feb 2026, 03:06 am »
I agree, just asking so people have an idea what to suggest, no sense in talking about xyz if it is way over your limit.
It would be good to start a new thread with your info and request.
« Reply #269 on: 4 Feb 2026, 05:56 am »
Do you live in a cold area ?
If not, forget tube amps and look Class D and GaN-Fet amps that will make you happier at a much lower price.
https://shenzhenaudio.com/products/s-m-s-l-pa400-power-amplifier?_pos=2&_sid=e9eb9eb60&_ss=r
chi0001
« Reply #270 on: 19 Mar 2026, 07:02 am »
Here’s an update for anyone interested in modifying the coupling capacitor and replacing some tubes.
I tried the Mundorf SGO 0.22 µF — it sounds good, but compared to the original capacitor, the Mundorf feels a bit boring.
Then I tried the 0.22 µF V-Cap — it also sounds good, but I still prefer the original more.
What really makes the sound different is changing the tubes.
I tried an RCA 829B (or similar), and there was an obvious difference. Long story short: after trial and error, I went back to the original settings and only replaced the 6N2 with a we420A (bald head version).
If budget is not a problem, I recommend using 0.22 µF V-Cap or Mundorf SGO for the coupling capacitor, paired with a Jupiter 0.01 µF as the bypass.
Jon L
« Reply #271 on: 19 Mar 2026, 03:45 pm »
Which V-Cap did you use?
This is why I try to live with stock coupling caps and tubes for awhile and compare one "upgrade" at a time.  Nothing wrong with the stock caps, and there is the system/taste preference thing..
chi0001
« Reply #272 on: 19 Mar 2026, 04:01 pm »
This is cutf, but I think the we420a is really worth a try. The sound is beautiful!
Jon L
« Reply #273 on: 19 Mar 2026, 05:42 pm »
Are you using 420a-to-12AX7 tube adapter?
chi0001
« Reply #274 on: 20 Mar 2026, 01:43 am »
yes, 5755 to 6n2.
