**FOUND** Rythmik FM8 pair.
0 Members and 1 Guest are viewing this topic. Read 1455 times.
nlitworld
« on: 27 Nov 2024, 03:55 am »
I've decided to shop around for a pair of Rythmik FM8 to work as speaker stands for NX-Studios. Small room and wish to cross over higher than standard would make that an ideal situation. Willing to trade a good condition GR Research Sealed Plus sub (A370PEQ amp) towards value if that sweetens the deal. Wish I had the space for Double Troubles but just not in the cards. Lots of other things I should spend $ on right now, but that is sounding like a good upgrade.
« Last Edit: 28 Nov 2024, 03:27 pm by nlitworld »
jmimac351
Re: WTB: Rythmik FM8 pair.
« Reply #1 on: 27 Nov 2024, 02:25 pm »
« Last Edit: 5 Dec 2025, 07:48 pm by jmimac351 »
Rocket_Ronny
    • ScriptureSongs.com
« Reply #2 on: 27 Nov 2024, 09:21 pm »
This I think is a very smart move and is what I have done for a pair of GR Super Mini's.
I move the speakers out to position for listening. That is why I made the handles. I also raised them off of the floor about 8" for a cleaner sound and to get the right tweeter height.
Rocket Ronny
jmimac351
« Reply #3 on: 27 Nov 2024, 09:30 pm »
« Last Edit: 5 Dec 2025, 07:47 pm by jmimac351 »
nlitworld
Re: **FOUND** Rythmik FM8 pair.
« Reply #4 on: 29 Nov 2024, 01:45 am »
Yep, I'm excited. I've seen several people mount them over the years and seeing yours Ronny made me pursue it further. I will likely need to boost a couple inches so I may have to rig something up with that. Gonna be fun!
jmimac351
« Reply #5 on: 29 Nov 2024, 01:49 am »
Rocket_Ronny
« Reply #6 on: 2 Dec 2024, 12:13 am »
Raising them off of the ground is VITAL if you are going to cross over 80 hz or so, as it cleans up the mid bass. I run mine all the way up to their 250 hz limit.
Rocket Ronny
nlitworld
« Reply #7 on: 2 Dec 2024, 03:31 pm »
Rocket Ronny
Yep, that's the plan. I'll make a base for them to raise the 4 or 6 inches it needs to get proper tweeter height. My couch sits a little low, but sitting with ear height +/- a few degrees in angle isn't bad.
Are you running any isolation devices between your FM8 and speakers? I currently have mine on IsoAcoustic Indigo and it really helped for on stands. I'll try both ways but I was curious of your experience with that part.
