Sold: VPI Mini HRX feet (set of four)
0 Members and 1 Guest are viewing this topic. Read 571 times.
Sarchi
« on: 26 Nov 2024, 09:37 pm »
SOLD
A major upgrade for Scout and Aries Series Tables. Or for Classic owners, these are the feet you'll find on the Classic Signature. I had them on my Scout (see pics) which I've since sold. They may be called 'Mini' but they aren't small and they weigh around 1 lb each.
"Upgrade the original coned feet on any Scout and Aries Series turntables ever made with the VPI Mini HRX Replacement Feet. These heavier and more stable composite HR-X style feet provide greater stability, vibration control and better sound.
This is one of the best, most affordable and easiest to install upgrades VPI has ever made. Just unscrew your existing coned feet and screw in your new VPI Mini HRX Feet to take your turntable one step closer in sound to VPI’s flagship model the VPI HRX!
The VPI Mini HRX Feet fit almost exactly inside the dimensions of your Scout or Aries plinths which means no incompatibility with dustcovers and the like!
The VPI Mini HRX Feet are quite heavy, well isolated and extremely stable. Made from a composite of Delrin and Stainless Steel similar to the plinth of the highly acclaimed VPI HRX, they also have a damping mechanism integrated into the design as well. The bottom of the feet have 3 steel ball bearings that are the contact point with your stand to further minimise vibration. The result of all these design features is a lower noise floor, tighter bass and improved overall clarity and soundstage for your VPI turntable. Easy to use and install. Just unscrew the existing coned feet beneath your plinth and replace them with the VPI Mini HRX Feet."
(There is a height difference, maybe 3/4", so just check that if you have a dust cover that sits directly on the support surface)
Nice condition with original box.
$220 PayPal + shipping approx $25 Conus.
« Last Edit: 28 Nov 2024, 05:02 pm by Sarchi »
jbetanc
Re: VPI Mini HRX feet (set of four)
« Reply #1 on: 28 Nov 2024, 04:54 pm »
sent you a pm
Sarchi
« Reply #2 on: 28 Nov 2024, 05:02 pm »
Sold
