April Music Stello CDT200 transport
0 Members and 1 Guest are viewing this topic. Read 6823 times.
Mad DOg
« Reply #20 on: 18 May 2005, 01:20 am »
Quote from: zybar
Thanks for the suggestions.
no prob!
Quote from: zybar
While I have no doubt how good the Silversmith products are, I am not willing to spend that kind of money on them.
i know what you mean...it's always easier to spend someone else's money!  :lol:
Quote from: zybar
As for the Stillpoints rack...I have owned the Stillpoints (not their rack) and I honestly prefer the Audio Points.  I will stick with my Sistrum stands and Audio Points.
i'd like to try the Audio Points and Sistrum stands. think i'll look into these. thanks for sharing your opinions!
JoshK
« Reply #21 on: 18 May 2005, 01:26 am »
I can tell you where you can source like 'Palladium'.  It isn't like their geometry is revolutionatry, its quite pedestrian really. You can make similar ICs for a ____ of the price.  I'll let you fill in the blank.  Look up Palladium's conductivity.
Mad DOg
« Reply #22 on: 18 May 2005, 01:53 am »
Quote from: JoshK
according to Jeff Smith, 100% Palladium has worse conductivity specs than silver or copper so i don't think he's using pure Palladium.
the Aural Thrills Palladium ICs use a pure Palladium conductor and they sound nothing like the Silversmith Palladium ICs.
JoshK
« Reply #23 on: 18 May 2005, 02:04 am »
I don't think there is anything such as 100% Palladium, since palladium, iirc is an mix by definition.  Palatinum and Iridium maybe?  Either of which would be less conductivity than silver or copper.
If I were inclined to spend that kind of dough on ICs (just in case it isn't clear, I'm not) I'd ask him to show some real factual evidence of this statement:
use a state-of-the-art palladium alloy that does not oxidize and has skin-effect related properties representing up to a 25 fold improvement over those of gold, silver, copper, and aluminum.
ekovalsky
« Reply #24 on: 18 May 2005, 07:12 am »
Quote from: JoshK
Palladium, platinum, and iridium are all individual elements in the "transitional metal" category, along with copper and silver and gold.  Conductivity in descending order is silver, copper, gold, iridium, paladium and platinum. Silver and copper are pretty close at the top, platinum and palladium are close at the bottom, and gold and iridium are in the middle with gold being the better of the two.
Iridium may be the hardest and densest element, also it has the greatest resistance to corrosion of any metal.  It is very expensive, at least as costly as platinum.  If someone could find a way to make wire out of iridium it would not be cheap or easy to work with.
Palladium is cheaper and frequently alloyed with gold -- "white gold".
Assuming the goal of a cable is high conductivity, copper and silver are the only real options.  For low power applications, there can be advantages to these other metals as well as carbon and other semiconductors.
 :o
tvyankee
« Reply #25 on: 18 May 2005, 02:21 pm »
hey phil.
i would be glad to bring it if  i am around.if not someone could pick it up if they want to bring it to you.
talk to you soon.
