Built: a dual-opposed, sealed, sonotube-based servo sub. And lamp!
0 Members and 1 Guest are viewing this topic. Read 11604 times.
dayneger
One thing I'd wanted to add is that, to my surprise, I'd accidentally chosen dimensions that made it "just" possible to use the stock wire leads on the Rythmik HX800 plate amplifier.
Apparently it's ok to make them a little longer if needed, but it was nice not to have to futz with anything (other than needing 3 hands to get the connections on while holding the heavy drivers)!
Not the best picture ever, but anyway:
tremrej65
Dang, not again!  If someone could tell me how to have my vertical shots not get autorotated to horizontal by the forum platform, I'd appreciate it.  :scratch:
To make sure a picture is in the right orientation, you can upload it in your galerie before writing the message. There's a tool in there to rotate it. You insert the photo in a message from the galerie.
By the way, I like the design of your sub. It looks amazing.
EricB
What a wonderful design. I'm sure you're very proud of what you've accomplished. It looks very elegant.
dayneger
Thanks for that helpful tip! I hadn't seen the manage photo option. I'll be certain to try that. Glad you like the look!
dayneger
Thank you so much! I do really enjoy the aesthetics in my room, and the bass performance is deep and musical. All part of the fun of DIY!
