Audio by Van Alstine DVA M225 Monos and DVA R2X - Sold
0 Members and 1 Guest are viewing this topic. Read 796 times.
figcon
All three pieces are sold
One pair of Van Alstine DVA M225's that were purchased from Van Alstine in May of 2023. They have had moderate use, meaning they are well broken in and operate perfectly. One small blemish above the power button on one of the amps, which I've tried to capture as well as possible. Any other blemishes in the pictures are a byproduct of bad photography. Original packing and manual, including power cords. I installed factory spec ceramic fuses in the speaker fuse receptacles. I also have the DVA R2X unbalanced to balanced converter that I used between my FET Valve preamp and the M225's. My GPA Altec 604 based speakers are around 98db sensitive and an easy load, so I'm able to use SET's and going that route. Best solid state amps I've ever owned and I'm not the only one that thinks that.  $2800 for all three, plus shipping will do it. If the converter isn't wanted, reduce to $2600. Sorry the pictures are sideways, but not how it shows up in my library and I've tried a bunch of tricks, but none have worked. Still, they have been reviewed by some heavy hitters at The Absolute Sound and others, so the pictures should get the point across.
« Last Edit: 9 Nov 2024, 01:11 pm by figcon »
RonN5
I've found that if you take the pictures that are in your library and then rotate them 4x...90degrees each time which gets them back to the original position...then save them...then post them...they will be in the proper position on your posting.
